ya, what bigred said. The almighty allison will break!!! You cant just throw tons of power at it and expect it to take it forever.
They were designed to last a LONG time, but only with the stock power.
What you did like bigred said was slip the clutches in the tranny. It went into limp mode because you damaged the transmission.
If you want things to go back to normal save up for an upgraded transmission. Then you can run your programmer at whatever setting you want, and not worry about it. (there's other supporting mods you'll have to do too... lift pump, FPRV shim, and more) But the point is that the stock tranny will only handle about 90hp extra, and then it'll limp.
You just started the ball rolling downhill. Put your truck back to stock and your tranny will last a while, depending on how hard you are on it. But it won't last that long so start saving!!!
