I just came in from dremel grinding my turbo inlet. Hopefully that will help some. Also I just noticed that just in front of the filter box opening on the fender there is some sort of sticky taped silver material and it covers a hole in the filter about the size of your fist. I pulled the stuff back and folded it down to open up that hole. That hole goes right down to the open air below the truck, It seems like that would suck in at least a little bit of cold fresh air from through the fender. Anybody know what that thick material is for and why it would be covering that hole? Seems useless, actually worse than useless its blocking air.... Thanks.
Brain
__________________ Brian
PPE Standard level 2
Kodiak mouthpiece
Truxedo Duece Tonneau
06 style leveled towing mirrors, 265 75 R16 BFG AT
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab, 9 'Flat/GN, Ride-Rite Air Springs, A/T Revos. Use-ta Haves 2005-LLY 3500 LS DRW Crew Cab, 2002-LB7 3500 LS DRW Crew Cab
"Did you ever think that making a speech on economics is a lot like pissing down your leg? It seems hot to you, but it never does to anyone else. " -Lyndon B.Johnson 100th
Sounds like stuff to quiet down the engine compartment or the shoot forget what its called, but the stuff you can put on you turbo to keep cooler like insulation, keep the rest of engine heat from warming it up more.
__________________ Meyer Performance & Fabrication, LLC Home of your diesel performance needs. www.meyerperformance.com (812)-344-4421 Tyler Quadzilla Sale pm for details. Airdog Sale EXTENDED till Jan. 31st. Transgo jr. $120 shipped
07.5 Summit White RCLB. DPF deleted, Cobalt gauges, Banks intake, Fire & ICE.
not sure why GM does that but i always pull that crap off to allow more air to the intake..
__________________ James
TyreBoyz Pulling Team
One would think GM designers are missing an opportunity for an aggressive look to the hood with the addition of a CAI scoop, nostrils, or cowl intakes.
It would sure improve things for us down south, been known to get a bit HOT down here.
Kodiak mouthpiece
That bottom pic is the hole that is uncovered and lets air in from the fender.
Kodiak mouthpiece
Kodiak mouthpiece
