Fuel rail pressure sensor???? - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 05-11-2011, 11:48 AM Thread Starter
I just got my truck diagnosed at chevy because it's not been idleing or running right and they said they need to replace my fuel rail pressure sensor. They said it's $700. Anyone have any advice to get it cheaper?
k2500 is offline
post #2 of 9 (permalink) Old 05-11-2011, 12:10 PM
Quicker Then Brian!
RedBowTies88's Avatar
very doubtful... its most likely your fuel pressure regulator which is >200 or possibly injectors.
whats the specs on your truck
Beech - 05 LLY CC/SB 4x4
12.31@108.57 On stock turbo and fuel system
Thanks to,
Big Dipper, Efilive, Calvert, Precession Converters, Nick@Duramaxtuner, Eaton, Pureflow, and Falken
RedBowTies88 is offline
post #3 of 9 (permalink) Old 05-11-2011, 04:16 PM
My truck was diagnosed today for a Fuel Pressure regulator also. Mine is doing something totally different. It is a 01 Duramax and it looses power going up hills pulling my trailer. They said it may fix the problem but may only be half the problem. Frustrating. My fix is quoted at 550(price & labor) right now. I quoted the part at Napa for $375 and that is with my companies discount.
Moorzluckee7 is offline
post #4 of 9 (permalink) Old 05-12-2011, 06:23 AM
Quicker Then Brian!
i got a brand new one for 150... do some more looking
Thanks to,
post #5 of 9 (permalink) Old 05-12-2011, 04:15 PM Thread Starter
SPECS: All stock, 6 in. fabtech lift, 35s, K&N intake, mbrp exhaust
k2500 is offline
post #6 of 9 (permalink) Old 05-12-2011, 06:03 PM
Administrator
jc1843's Avatar
I suggest you do the "bottle test" to check the FPRV--[Fuel Pressure Relief Valve] that is the sensor on the fuel rail. LLY engines do have a weak spring in the FPRV.
On the drivers side fuel rail near the firewall there is a horse shoe shaped 1/4" hose close to the glow plug bracket. Disconnect the hose where it comes out of the fuel rail. Then hook up long hose and plug the "U" shaped hose.
Run the hose to somewhere that a bottle can be mounted. If your hose is long enough, you can mount it between the coolant tank, and airbox. Anywhere you can have the bottle standing in a upright position.
Now drive the truck hard, with some wide open throttle runs.
After you do this, check the bottle. If its empty, your FPRV is not bleeding off fuel and you don't need to shim the valve.
If it has more than a little fuel, that means that your fuel rail relief valve is leaking and you will then need to either shim the valve, or install a race valve.
PM sent---
jc1843 is offline
post #7 of 9 (permalink) Old 05-12-2011, 06:23 PM
TrevorG's Avatar
check merchant automotive for an fpr $175. merchantautomotive.com
Trevor
LLY
Blocked, Rerouted, Sleeved, MP, 5"
Cobalt's, Leveled, Raptor, Profab, DDM, K2
EFI by ATP
TrevorG is offline
post #8 of 9 (permalink) Old 05-15-2011, 06:38 AM Thread Starter
Thanks yall. jc, im gonna try to do that monday, see what happens before i spend money on somethin (sensor) i may not even need.
k2500 is offline
post #9 of 9 (permalink) Old 05-15-2011, 06:42 AM
usafduramax's Avatar
if you need a fpr you can get one for cheap from alligator performance and do it yourself..it's not a lot of fun to do but it'll save you money thats for damn sure lol
usafduramax is offline
