Old 09-18-2008, 02:49 PM   eBay Motors   #1 (permalink)
Dusty Roads
Dusty Roads's Avatar
Bad Mileage
I have an 04.5 LLY and have been getting pretty bad mileage lateley. Around 80,000 miles I have seen a decrease in mpg performance. I used to avg 17-18 @75 mph. Now lately I have been driving slower 65-70 and only getting about 14 on freeway and 9-10 on the farm. I had the BANKS 6-gun on it before and took it off around 95,000. Currently I have 110,000 mi (5,000hrs on engine). I did not see any difference in mpg with it before or after. I changed filters and ran diesel cleaner in the fuel as well but no change. I also have the Banks intercooler, air intake and exhaust on it as well. Has anyone else have this problem? Any recomendations on maybe better programmers/tuners?
I have heard that around 80,000-100,000 mi the CATS start to plug real bad. I wonder if this is the case since I have a lot of idle time. Also been thinking about cutting my CATS off but am leary of losing performance and throwing codes. Any ideas?
Dusty Roads is offline   Reply With Quote
Old 09-18-2008, 02:54 PM   eBay Motors   #2 (permalink)
86burgandyss
86burgandyss's Avatar
You would gain performance when you remove the cats, not sure about the codes. I throw an egr code on occasion, but I have a turbo back system.
07 classic crew cab long bed 2wd
3.73 rear, stock tire size
86burgandyss is offline   Reply With Quote
Old 09-18-2008, 03:04 PM   eBay Motors   #3 (permalink)
bigdaddydiesel
bigdaddydiesel's Avatar
Idle time will kill your overall MPG results, no matter what you do, and yes, removing the Cat should help.
Chris Kelley
Dealer Referral ID # 1678239
Email
1-888-563-5143
Winter Blend Fuel Additives
Old 09-18-2008, 03:25 PM   eBay Motors   #4 (permalink)
Dusty Roads
I know idle time will kill mpg, but recently All I have are hwy miles w/ no idle time and I am still only getting about 14 mpg. It just seems like my mileage really dropped off the map. My range is only 350-360 miles before I need to be back at the fuel pumps.
Old 09-18-2008, 03:37 PM   eBay Motors   #5 (permalink)
Dusty Roads
Would you know if I would need a fingerstick or an EGR Blocker?
Old 09-18-2008, 05:53 PM   eBay Motors   #6 (permalink)
midieselguy
midieselguy's Avatar
Dusty Roads,
I have the same engine with the mods listed in my sig. I get 20-21 MPG at 75mph. My biggest gains came with the turbo back exhaust and KB's IOH kit. Around town my mileage drops to 15-16. I'd take the cat off and let it breathe.
2004.5 LLY, X-Cab, short-bed, Allison Trans, 4" MBRP Turbo-back, no cat, KB's IOH kit, EGR block plate, no finger stick, MB Razor 16x8 with BFG AT 285's
midieselguy is offline   Reply With Quote
Old 09-18-2008, 07:36 PM   eBay Motors   #7 (permalink)
bowhunternkbay
bowhunternkbay's Avatar
I would bet that with that kind of mileage, soot buildup is pretty extensive...both in the cat and in the intake from the EGR. Research for getting rid of the soot buildup in the intake is nothing short of removal.
'06 2500 HD CC/SB
BullyDog TripleDog
AiRaid CAI
MBRP 4" Turboback
Goodyear Silent Armor LT 285/75R16
Blocked,Fingered,Rerouted,Sleeved and Plugged
www.DiscountTireDirect.com
bowhunternkbay is offline   Reply With Quote
Old 09-18-2008, 10:34 PM   eBay Motors   #8 (permalink)
Dusty Roads
Originally Posted by midieselguy View Post
Dusty Roads,
This might be a stupid question but what is the KB'S IOH kit?
Old 09-18-2008, 10:42 PM   eBay Motors   #9 (permalink)
Dusty Roads
Do you have pics/ instructions on how to put in the block plate? Do you also know where to get a finger stick and the proper way to install it?
Old 09-19-2008, 04:45 AM   eBay Motors   #10 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
A flaw exists with the design of the intake turbo mouthpiece on the LLY motor. Porting the mouthpiece is a simple solution, or as mentioned above, an IOH (induction overhaul) kit will update the MP to the current GM LMM design in use.
Review these threads for more info:
ported mouthpiece pic
LLY mouth piece????
While this mainly addresses performance and overheating issues, is does offer a slight increase in mileage. Your problem is somewhat different as your mileage has decreased with more miles put on. I have the same issue, I once saw 17.3 mpg running unloaded, while the best I currently have seen is just under 15. Check my sig.
