Old 09-19-2008, 12:07 AM   eBay Motors   #1 (permalink)
redinator
PPE love it but confuseed
So i just got my new ppe standard today and love it. . but i am confused about something. . as i was first installing the download it didn't work. . . . as in the pcm updating screen stayed on for 4hrs!!! and i have no idea why but after i waited around i pulled it out and it works fine. . is this normal or not?? by the way i am new with downloads and tuners so this may be an easy answer. . idk
redinator is offline   Reply With Quote
Old 09-19-2008, 04:49 AM   eBay Motors   #2 (permalink)
OneBadDmax
OneBadDmax's Avatar
You may have forgot to press a certain button and it was waiting for you. My first PPE was malfunctioning and it wouldn't work so I returned it, got a new one, and now it works perfect.
2006 Silverado Duramax
Ext. Cab Short Bed.
MBRP 4" T/B SS
PPE
Autometer Cobalt boost and Pyro
Hummer wheels with 285/70/17 Nitto Terra Grapplers
Whelen amber strobes on back rack with amber strobes in the grille.
Back Rack
Boss Plow
OneBadDmax is offline   Reply With Quote
Old 09-19-2008, 06:55 AM   eBay Motors   #3 (permalink)
blackdeath
blackdeath's Avatar
unplug and try agin ,, its hapened to me a couple times,i think sometime they get a communication error from pcm ,or even bcm if something is touched or moved
2008 silverado dmax LTZ, aFe stage 2,race tune from idahorob,EFI LIVE, AD 150 lift , ppe shim kit,dpf delete,EGR block off plate,autometer gauges (cobalt) boost and pyro,transgo jr,6"fabtech with maxxcams and 2"addleaf,fabtech tierods,37"procomp 20" boyd wheels. 5% tint all around,5"grandrock stack kit,straight piped, custom painted dash panel,SCIV coming maybe
2008 trailblazer ss, straight pipe ,jetttstream air intake,iat relocate kit,efi tuned , 3" lowered
blackdeath is offline   Reply With Quote
Old 09-19-2008, 07:05 AM   eBay Motors   #4 (permalink)
jc1843
did you remove the fuses that they tell you to in the instructions? The first time you use it, it downloads all the computer information into the PPE (This can take a while-10 minutes or more) then uploads the new tune (couple minutes) 4 Hours is way to long- remove it and try again.:cool
Chevy 04.5 LLY, 265s, shell, XDR, MikeL 6spd, TransGo, deep pan, blocked, fingered, de-badged, PVC, 65 Gallon Aero tank, PPE, LBZ- mod, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags
Old 09-19-2008, 10:06 AM   eBay Motors   #5 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
i have had it happen a few times if your key is in the on postion to long it will power down the ECM to save battery,like when i first tune a truck it has to save the stock info which takes roughly 12-15mins and then when i start downloading a tune it will say comunication error,simply start over and it will work fine.
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 09-20-2008, 12:18 AM   eBay Motors   #6 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
I agree with TYREBOYZ. Probably something simple. Id retry it and see what happens! When you started the truck did it run better? Did the tune install?
Jason
Old 09-20-2008, 10:14 AM   eBay Motors   #7 (permalink)
redinator
yea it installed itself the second time but ur pry right i don't think i hit the right button somewhere along the line. . also does it matter if the park brake is on because that could of possibly been my problem. . and also do i need to pull those fuses everytime i change tunes??
Old 09-20-2008, 11:49 AM   eBay Motors   #8 (permalink)
K9Duramax
K9Duramax's Avatar
Yeah, pull fuses every time. What I do is roll the window down and do it from there and make sure dome light override is on (no domelight). That way there is no interuptions during process- do everything from the open window and can look into monitor process if need be and presto. Good luck, you'll love the PPE.
'05 CC/SB, AMSOIL 5w-40, KN Cold Air Intake, PPE Tuner level 1, EGR blocked, MP mod, res. plugged, lost KITTY, finished off the rest with 4" SS Magnaflow
Synthetic Motorsports
http://lb7.info/
K9Duramax is offline   Reply With Quote
Old 09-21-2008, 06:40 PM   eBay Motors   #9 (permalink)
BigRedChevy
Super Moderator
BigRedChevy's Avatar
It doesn't matter about the prake brake. Mine did that a couple times, but always worked the second time.
KYLE
2010 Camaro SS LS3 426 HP
