06-07.5 LBZ & LLY Duramax PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
My belief is that the LLY has a different CARB standard than the LBZ, emissions certified to different requirements. Besides some tuning changes to the ECM, there are no other differences.
MIne is a 06 lly and it was rated 310 hp but does have a six speed everything that I have bought for mine is the same as the lbz. Also the changes of routings for the intercooler and stuff are the same on mine as the lbz
__________________ 06 chevy lly crew cab 4x4 s/b
3" keys up front 1" block in rear
20x10 Moto Metal 955
305 terra grapplers
4" silverline turbo back exhuast
Edge juice with attitude hot unlocked
intake modified
resonator blocked
access literider roll up tonneau cover
Does anyone no for sure if the dealership can turn the LLY's power to the LBZ power.
The look of everything under the hood is exactly the same as my buddies LBZ. I don't see what the big deal would be.
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab, 9 'Flat/GN, Ride-Rite Air Springs, A/T Revos. Use-ta Haves 2005-LLY 3500 LS DRW Crew Cab, 2002-LB7 3500 LS DRW Crew Cab
"Did you ever think that making a speech on economics is a lot like pissing down your leg? It seems hot to you, but it never does to anyone else. " -Lyndon B.Johnson 100th
The straight answer is, the dealer will never do this for you. To be honest, none of them even know how. Even if they did know how, they would technically be commiting a "clean air act" federal offense. (don't ask).
I am not a dealer, but my basic understanding is that the VIN controls the PN of the tune components that the vehicle recieves per GM spec. If they used an LBZ VIN, then you might be able to do a flash with the right components. They probably also risk damaging something.
HOWEVER, with EFILive, you can put the LBZ parameters into the LLY very easily, then you have essentially identical vehicles. I have done this.
That is correct everything is vin driven, and those guys get scared shi$less when thay are crossing lines like that I have seen a few PCM's locked up and then who's to blame?
__________________ 2005 LLY CCSB
Leather, Bose, XM
Truxedo bed cover, Line-X
305/75/16 BFG M/T's Ready Lift Leveling kit
B&W Turn-over-ball
Resonator plugged
NO CAT!!!!
Superchips Flashpaq (It was free and now I know why what a P.O.S.)
BG Synthetic fluids throughout!
That should answer your question.
would that apply to even a 05 lly?
__________________ 2005 LLY C+ SB
Pace Edwards---Jack Rabbit
Vent Visors
