Old 10-04-2008, 02:38 PM   eBay Motors   #1 (permalink)
oleblacky
oleblacky's Avatar
Are they the same?
Alright I know this has been answered before but, is the hp rating on the 06 LLY the same as a 06 LBZ?
2006 Silverado LT Crew Cab
Durmax LLY Allison/6speed
Straight Piped Kitty Ran Off
Resinator Plugged PCV Reroute
285/75/16 M/T wheels
Work Truck 08 LT LMM
Summit White Crew Cab
Bone Stock
oleblacky is offline   Reply With Quote
Old 10-04-2008, 02:48 PM   eBay Motors   #2 (permalink)
BigRedChevy
Post Slut
BigRedChevy's Avatar
I think it is still 310 for the 06 LLY
KYLE
Old 10-04-2008, 02:50 PM   eBay Motors   #3 (permalink)
Hook'em_Horns!
On edit...same motor, different tune.
Old 10-04-2008, 02:54 PM   eBay Motors   #4 (permalink)
Hook'em_Horns!
Note specs below:
Specifications
Engine Code: LBZ
Displacement: 6.6L / 403 in³
Bore x Stroke: 4.06 in (103 mm) x 3.90 in (99 mm)
Block / Head: Cast gray iron / Cast aluminum
Aspiration: Turbocharged & Intercooled
Valvetrain: OHV 4-V
Compression: 16.8:1
Injection: Direct; Bosch High Pressure Common-rail
Power / Torque: 360 hp (268 kW) @ 3,200 rpm / 660 lb·ft (895 N·m) @ 1,600 rpm
Specifications
Engine Code: LLY
Valvetrain: OHV 4-V
Compression: 16.8:1
Power / Torque: 310 hp (231 kW) @ 3,200 rpm / 605 lb·ft (820 N·m) @ 1,600 rpm
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab, 9 'Flat/GN, Ride-Rite Air Springs, A/T Revos.
"Did you ever think that making a speech on economics is a lot like pissing down your leg? It seems hot to you, but it never does to anyone else. " -Lyndon B.Johnson 100th
Old 10-04-2008, 03:06 PM   eBay Motors   #5 (permalink)
oleblacky
oleblacky's Avatar
Well that sucks thanks guys. I knew ya'll could do it!!!!!!!!!!!
Bone Stock
Old 10-04-2008, 03:08 PM   eBay Motors   #6 (permalink)
Hook'em_Horns!
They are the same engines in '06, just different tunes. Could this be changed?
Old 10-04-2008, 05:42 PM   eBay Motors   #7 (permalink)
FH Leader
FH Leader's Avatar
a dealership will up the hp on a 06 lly to the LBZ rating. well that is what they told me when I was buying my truck. the other thing is the LBZ has a larger water pump or that is what the shop manager. One of the other guys will chime in and could tell if that is true or not and what is the same and what they changed from the lly to the lbz.
Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
06 LBZ with 5 inch magnaflow exhaust,Bd exhaust manifold, Bully dog outlook, Egr blocker, Firestone air bag system,Custom sound system, dual fuel filters,leveling kit, B&M deep tranny pan,TTS lift pump,Turbo Resonator plugged,Cooper ST 265/75R16, Bully nerf bars and B&W guardian headache rack sprayed with reflex bed liner, B&W turn over ball,B&W Tow&Stow, transgo jr, efi live, tranny filled with transynd, Tierods sleeved
Omaha Truck and Trailer offering Woodworth custom build trailers.
Now a factory authorized Whelen dealer
My iron is yellow
FH Leader is offline   Reply With Quote
Old 10-04-2008, 09:14 PM   eBay Motors   #8 (permalink)
daddysLBZ
NUMBERONEHOTSHOT!!!!
daddysLBZ's Avatar
There are a few differences,but mostly in the tunes.The 06 LLY is a lil diff than the 05's IIRC[comp ratio/different?]cooling system is improved also.
2006 GMC 2500hd4x4SLE cc/sb...LBZ
HIFLO exhaust & ''HP enhancers''.
2002 GMC ex cab15002wd
1987 Monte Carlo SS
1978 Malibu/RUNS
2002 YukonXL321k,tuned!
The left lane is built to pass,move or we'll run over yurassss!!Try me..
2005 Kodiak...don't ask!
Kevin
''FORSHO''[Tm]
Old 10-04-2008, 09:37 PM   eBay Motors   #9 (permalink)
n0useforaname
Knows your Mom
n0useforaname's Avatar
Does the 06 LLY have the 6 speed Ally?? I thought it was a 5 speed? I thought that was another reason they upped the HP.
LIFT: Ready Lift Leveling Kit
SOUND: Pioneer P4000DVD - 6 1/2 Polk Audio everywhere else.
ADD ONS: H1 Halo Projector headlights, Backup Camera, Dee Zee running boards, Chrome Grill, ExTang Solid Fold Tonneau Cover, Line of Fire w/reverse, custom bug shield/vent shades, TomTom GPS
TIRES/WHEELS: 285/75-16 Firestone MT Tires on 16x8 ATX series Teflon Coated Wheels
Old 10-04-2008, 09:40 PM   eBay Motors   #10 (permalink)
daddysLBZ
daddysLBZ's Avatar
Thumbs up
I beleive that some of the 06's have the 6 speeds..VIN numbers tell the tale when it comes to the tuning part though.Mine was built in April 06 and has a ''D''as the eighth # in the VIN...=LBZ!!you know n0use!!!
1987 Monte Carlo SS
1978 Malibu/RUNS
Kevin
''FORSHO''[Tm]
