Old 10-21-2008, 07:52 AM   eBay Motors   #1 (permalink)
DSLPWR
Stopping Power
Used a gooseneck recently to pull my boom. NO problem pulling. BIG problem with BRAKING. Any recommendations!! Bigger brake system? Exhaust break???
2007 2500HD 4x4 CC Classic SB Summit White MBRP Dual Turbo Back Exhaust; Airaid CAI; 22" chrome wheels w/ 33"Toyo tires; Line-x bedliner; PPG programmer
2005 Dodge Ram SRT 10 Quad Cab Yellow Fever NOT STOCK
DSLPWR is offline   Reply With Quote
Old 10-21-2008, 08:06 AM   eBay Motors   #2 (permalink)
BigRedChevy
Post Slut
BigRedChevy's Avatar
Was your trailer brakes working?
An exhaust brake would be a very good add on.
KYLE
Old 10-21-2008, 08:31 AM   eBay Motors   #3 (permalink)
DSLPWR
Trailer breaks were working. Maybe I had the setting to low ( 3).??
Old 10-21-2008, 08:32 AM   eBay Motors   #4 (permalink)
DSLPWR
Any suggestions for LARGER brakes ?? Is it more cost effective for an exhaust break???
Old 10-21-2008, 08:33 AM   eBay Motors   #5 (permalink)
Meyerperformance
DPF Delete man
Meyerperformance's Avatar
powerslot rotors, and i would only consider exhaust brake if tow quite often.
www.meyerperformance.com
(812)-344-4421 Tyler
Quadzilla Sale pm for details.
Airdog Sale EXTENDED till Jan. 31st.
Transgo jr. $120 shipped
07.5 Summit White RCLB. DPF deleted, Cobalt gauges, Banks intake, Fire & ICE.
Old 10-21-2008, 08:58 AM   eBay Motors   #6 (permalink)
BigRedChevy
Post Slut
What does that load weigh? It really just sounds like you just didn't have your trailer brakes set up high enough.
KYLE
Old 10-21-2008, 09:05 AM   eBay Motors   #7 (permalink)
daddysLBZ
NUMBERONEHOTSHOT!!!!
daddysLBZ's Avatar
Yep,when trailer brakes are working properly,they should be able to almost drag the truck to a stop..I have set the gain too high upon taking off and the 1st time I applied the brakes,smoked all 8 tires on the trailer..With the trailer unloaded test the gain when pushing the brakes,you should feel the trailer tug a [LITTLE]on the truck,not a lot though.Then you can adjust when you get the feel of the load on there..
2006 GMC 2500hd4x4SLE cc/sb...LBZ
HIFLO exhaust & ''HP enhancers''.
2002 GMC ex cab15002wd
1987 Monte Carlo SS
1978 Malibu/RUNS
2002 YukonXL321k,tuned!
The left lane is built to pass,move or we'll run over yurassss!!Try me..
2005 Kodiak...don't ask!
Kevin
''FORSHO''[Tm]
Old 10-21-2008, 09:24 AM   eBay Motors   #8 (permalink)
DSLPWR
total load of trailer and equipment was 15,750 lbs. Sounds like I should have had the brake controller set to a higher setting!!
Old 10-21-2008, 09:28 AM   eBay Motors   #9 (permalink)
Durallymax
Durallymax's Avatar
You have other issues if thats all that you were towing.
Like ive said time an again we gross over 45,000 with our 02 and it stops the load fine. No fancy brakes or brake pads or exhaust brakes. Just a nice prodigy brake controller.
The "Dieselholic"
Dieselholic Homepage
'03 GMC 2500HD LB7/Allison EC/SB 4x4 Dark Charcoal Metallic SLT. Injectors at 84,000. Sled Puller/DD
EFI Live: V7.5.5/V8.1.2 OS:03904405
Suncoast IV w/1055
512rwhp 1085lb-ft
13.6 @ 99mph
Many mods to come over the winter.
Durallymax is offline   Reply With Quote
Old 10-21-2008, 09:29 AM   eBay Motors   #10 (permalink)
daddysLBZ
daddysLBZ's Avatar
Yes and no....Too high of a setting is bad news..Just do the empty test like above,then adjust the gain up some more after you get the load on there.IF your brakes are workin properly,try this: Unloaded the trailer should drag the truck to a stop,you want it when you hit the brakes unloaded,to give some slight drag on the truck,kinda like a lil tug back on the truck at the end of your stop..
1987 Monte Carlo SS
1978 Malibu/RUNS
Kevin
''FORSHO''[Tm]
