Old 11-03-2008, 04:25 PM   eBay Motors   #1 (permalink)
oleblacky
oleblacky's Avatar
Cooler lines?
Allright guys, yesterday I was messin around with the truck (LLY) and noticed a leak in one of my tranny cooler lines where it is crimped. My question is has anyone changed them to high pressure rubber hose or ran another kind of line.
It looks like to me that the factory lines are plastic and I ain't to fond of plastic.
2006 Silverado LT Crew Cab
Durmax LLY Allison/6speed
Straight Piped Kitty Ran Off
Resinator Plugged PCV Reroute
Transgo Jr.
285/75/16 M/T wheels
Work Truck 08 LT LMM
Summit White Crew Cab
Bone Stock
oleblacky is offline   Reply With Quote
Old 11-03-2008, 04:51 PM   eBay Motors   #2 (permalink)
offroadmatt
offroadmatt's Avatar
Had a similar problem with mine (07 Classic LBZ). Except mine chaffed throgh where they cross over the rack and pinion for the steering, both lines would catch on the tie rod end and smash up against the oil pan. Changed out both of the lines with stock, not fun. Secured the lines up out of the way. Haven't had any problems since. Not sure if the new lines will fit or not, but they are made of metal and rubber. Cost me $182 for both lines and about 3 hours to change them myself.
offroadmatt is offline   Reply With Quote
Old 11-03-2008, 04:55 PM   eBay Motors   #3 (permalink)
Chevyguy08
Chevyguy08's Avatar
there is an update for 07 classic tranny cooler lines should be under warranty had done on my 07
Chevyguy08 is online now   Reply With Quote
Old 11-03-2008, 05:23 PM   eBay Motors   #4 (permalink)
offroadmatt
Do you know what the update is, hope it was different shaped lines.
Old 11-03-2008, 05:35 PM   eBay Motors   #5 (permalink)
oleblacky
oleblacky's Avatar
The local parts store told me the line was 6.99. I think that was a little to cheap, but we will see. They had to order it. It looks like they are held in with quick connects like are on some fuel lines. There's got to be a way to change that too.
Transgo Jr.
Bone Stock
Old 11-03-2008, 09:09 PM   eBay Motors   #6 (permalink)
Durallymax
Not sure about up by the cooler but on the tranny there is a littel clip that holds them one.
Slide the little plstic cover back, and pop that little clip out. Give the line a yank and there you have it. Unless 6spds are different
The "Last Minute Puller"
'03 GMC 2500HD LB7/Allison EC/SB 4x4
Suncoast, EFI Live, S400, Studs, Stock Motor
Badger Truck Pullers Association Member
Thanks to all of my sponsors
Durallymax is offline   Reply With Quote
Old 11-04-2008, 08:30 AM   eBay Motors   #7 (permalink)
Chevyguy08
Chevyguy08's Avatar
when the cooler lines where crimped they werent crimped correctly and will start to leak over time mine had about 23,000 on it when i noticed it leaking, i had mine up for the egr update and got it back and noticed the lines were leaking so took it back to the chevy garage and they said oh ya there is update for that to but we didnt think it needed it, plus they had the lines it stock
Old 11-05-2008, 10:39 AM   eBay Motors   #8 (permalink)
oleblacky
oleblacky's Avatar
I'll call the stealer and see if the update is for mine too. If not I'm goin to do some figurin on how to go to a different style line.
Transgo Jr.
Bone Stock
Old 11-13-2008, 10:59 PM   eBay Motors   #9 (permalink)
Toypuller
We replace those all the time. I am actually doing both oil cooler lines and both tranny lines on one right now. 56K on the truck. thats it.
Old 11-13-2008, 11:37 PM   eBay Motors   #10 (permalink)
oleblacky
oleblacky's Avatar
Well after some figurin and cussin I changed all the lines to 1/2 hydraulic steel braided line with crimped on fittings. It might be a little overkill but I don't have to worry about them leakin anymore.
Transgo Jr.
Bone Stock
