vibrations at idle - Chevy and GMC Duramax Diesel Forum
Old 01-11-2012, 08:19 PM   eBay Motors  #1 (permalink)
John-Boy 331's Avatar
vibrations at idle
ok, been getting worse and started before i did fuel and air filter; in nuetral idleing it isn't to bad but in gear and idleing its getting worse, you can mainly hear it in the cab, feel it in the steering wheels and pedals, and as soon as you give it any kinda fuel pedal it goes perfectly normal,.....and coming to a stop once the engines at fuel idle even still rolling same thing, and sometimes some of the shifts feel like it has a clogged fuel filter. if it helps my milage hasn't dropped any, the past weekend to and from a race at 20.25 any fuel treatments i should try or what else
2011 lml 2500hd 4x4 lt ecsb taupe gray. 3" mbrp down pipe, 4" flo-pro straight pipe, egr and resonator blocks, and efi live autocal w/o any extra horses
Sold 06 LBZ 3500 4x4 single rear wheel regular cab long bed WT, 4" turbo back straight pipe, solid gooseneck, drw wrecker prep springs, blocked, fingured, 2"plugged, and plenty of UWS boxes
John-Boy 331 is offline   Reply With Quote Quick reply to this message
Old 01-11-2012, 08:33 PM   eBay Motors  #2 (permalink)
gr8shot's Avatar
honestly, by the symptoms, it sounds like a broken motor mount. But it could very well be an injector issue causing a misfire or something of the sort. First thing I'd do is get the injector balance rates checked out and see what they are. If one of them is way out of whack then that will likely tell you more than I can.
Jesse
2004 LB7
Tastefully modded
Lots of miles
Built by Husker Diesel
gr8shot is offline   Reply With Quote Quick reply to this message
Old 01-11-2012, 08:38 PM   eBay Motors  #3 (permalink)
lddrew's Avatar
check to see if your exhaust is hitting the frame anywhere.
what's the best way to tell about a motor mount jesse?? have a guy rev it while you look in the engine bay? they move a lot just revving with good mounts though
-Lee-
LBZ Crew - EFI - MBRP - Profab - Airdog
Raptor lined rockers and flares by me
my "build" thread
Raptor color match thread
ATP Trucks
lddrew is offline   Reply With Quote Quick reply to this message
Old 01-11-2012, 10:45 PM   eBay Motors  #4 (permalink)
rbox's Avatar
My truck is having more or less the same symptoms and I am curious about the engine mounts also. I'll be interested to see what you find.
2007 GMC 2500HD Duramax CC 4x4 - All Stock
rbox is offline   Reply With Quote Quick reply to this message
Old 01-12-2012, 08:55 AM   eBay Motors  #5 (permalink)
gr8shot's Avatar
I'm not sure how you'd go about checking them out. I would doubt they're actually bad though. I've just had to replace one in my car and one in my fiance's sisters car in the past couple weeks so it was on my mind. Both cars had bad vibration at idle. One was bad enough that the mount had worn and was metal on metal unless the motor was under load. On our car the motor would move... a lot... when you go from park to in gear or from drive to reverse.
Sent from my phone, probably while driving and eating a sandwhich
Jesse
2004 LB7
Tastefully modded
Lots of miles
Old 01-12-2012, 09:07 AM   eBay Motors  #6 (permalink)
Pura.Vida's Avatar
I have had a similar lopy jiggle/shudder. Can you put your foot on the brake with it in gear and give it a slight amount of fuel and make it do it? I can do this and re-create the symptoms. This was making me think that my torque converter was going on me. I would love for this not to be that case so anyone with some suggestions on how to chase this down would be great.
Mine is right when I get on the gas when leaving a stop light, and right when I come to a complete stop at a light. It will sometimes randomly jiggle/shudder while sitting still. You can feel it in your pecks/moobs when it does it, for what thats worth.
Jordan
05 LLY CC SB 4X4, K&N ON LBZ INTAKE, RESONATOR PLUG, LBZ MP, 4" SILVERLINE, PCV RE-ROUTE, PORTED FUEL RAIL FITTING, EGR DELETE TUBE, FPRV SHIMMED, AIR DOG II 165, DEEP PAN/FILTER LOCK, TRANS-GO JR SHIFT KIT, SYN BLEND TRANS FLUID, PPE STANDARD, H2 WHEELS WRAPPED IN 295 GRAPS, HID H/L/F ALL ON, LED PLATE LIGHTS, MANUAL HIGH IDLE, GATORBACK SERP BELT, TORSION KEYS, TIE ROD SLEEVES, ARP HEAD STUDS
Oxcart- 01-18-2011, 11:43 PM
Thread-efi smoke tune help
"You will be back hippy."
Pura.Vida is offline   Reply With Quote Quick reply to this message
Old 01-12-2012, 08:14 PM   eBay Motors  #7 (permalink)
mines only idle, if you hold the brake and give it just a c-hair of throttle its perfectly smooth, it does thump from drive to reverse alittle, and the exhuast isn't rubbing anything
Old 01-12-2012, 08:56 PM   eBay Motors  #8 (permalink)
lddrew's Avatar
hmmmm. maybe it's just a 6.6 liter motor doing work. i dunno. It kinda weirds me out too. The idle speed seems like it changes a little bit, like it's cycling something. i have no idea
-Lee-
my "build" thread
ATP Trucks
Old 01-13-2012, 04:50 AM   eBay Motors  #9 (permalink)
Dieselgooroo's Avatar
My does this to kinda. I figured it was just a diesel. I had a cummins before though. Little rattely.
Sent from my PC36100 using AutoGuide App
Click here for nude pictures performancetruckproducts.com
Dieselgooroo is offline   Reply With Quote Quick reply to this message
Old 01-13-2012, 05:30 AM   eBay Motors  #10 (permalink)
yea it ain't normal, i've had this truck from 6 miles and this is the first time its ever made the the inside of the cab sound like a rattling drum at a stop light. from past experences with diesel alge and bad filters it seem like a fuel issue but like i said i've replaced fuel and air filters and no change. will look into the motor mounts though, seems like that could be something there
