07 , 6.6 goes to limp mode - Chevy and GMC Duramax Diesel Forum
Old 01-15-2012, 05:03 PM   eBay Motors  #1 (permalink)
cowboyjoe0602's Avatar
I have had this problem for about eight months now. my truck truck just goes into limp mode while towing a load and only does when towing. it feels as if it just isnt getting the required amount of fuel needed, i installed a chip that has helped.
Any answer out there? anything will help have all ready ran out of options.
Change filters frequently, taken to dealer and shops, still no answers
cowboyjoe0602 is offline   Reply With Quote Quick reply to this message
Old 01-15-2012, 06:03 PM   eBay Motors  #2 (permalink)
TakeEm's Avatar
What does the check engine light say? Any codes? What programmer are you running and what power level while towing?
Sent from my Autoguide IPhone app
Caleb
2007 LBZ CCSB Wehrli S475/stock-Suncoast by Dmitri
EFI Live: 620HP 1220TQ
5" DE, rerouted, debadged, demolded, air dog, stock fuel
TakeEm is offline   Reply With Quote Quick reply to this message
Old 01-15-2012, 06:06 PM   eBay Motors  #3 (permalink)
duramax9878's Avatar
get the codes if you could that will help a ton
im goin to guess it is going to be a low fuel code and a shim kit may help or a lift pump
06 LBZ Dmax Toy Truck
07 LMM Dmax Tow Rig
duramax9878 is offline   Reply With Quote Quick reply to this message
Old 01-15-2012, 06:34 PM   eBay Motors  #4 (permalink)
rebpdt's Avatar
A chip?? What brand "chip" did you use
CCSB LB7 4x4
rebpdt is offline   Reply With Quote Quick reply to this message
Old 01-15-2012, 06:58 PM   eBay Motors  #5 (permalink)
woodchuck2's Avatar
Fuel filter plugged? Fuel line collapsing? I would check the fuel lines and install a lift pump.
2006 ECSB LBZ, 8' Fisher plow, Saltty Dog sander, tinted windows, bedliner, 265 Cooper Discovery M/S, home made rear pull plow, PPE air box mod, "kitty ran off" straight piped with Flow Master 50 series muffler, Predator on 120hp tune.
Sold 2006 RCLB LBZ, set up for plow and sander, Line-X bedliner, DeeZee running boards, 285 Cooper Discover S/T. Truck will be missed.
woodchuck2 is offline   Reply With Quote Quick reply to this message
Old 01-15-2012, 07:04 PM   eBay Motors  #6 (permalink)
i am running a cortex that i originally bought for my 08 chevy 6.0
-in the past i have had a (p0650 mil control circuit problem)
-also had a low fuel rail pressure
-but it has been a long time since i have had any codes and it does it frequently
Old 01-15-2012, 07:09 PM   eBay Motors  #7 (permalink)
Slave to the Interwebs
Johnasara's Avatar
How are you running a gasser tuner on your diesel??
How many miles are on your 07?
Is it a new body style or Old body style?
WORK RIG
2014 3500 CREW,DUALLY, LML, HARBOR 9' UTILITY BED Bone Freakin Stock
Johnasara is offline   Reply With Quote Quick reply to this message
Old 01-15-2012, 07:19 PM   eBay Motors  #8 (permalink)
this tuner is compatible with all gm . i just logged onto the superchips ad downloaded the program for the duramax with a fee. so now in order to use with the other i have to pay and change it back. but im looking for one specifically for the duramax now and need to fing the problem that i am also having
Old 01-15-2012, 07:29 PM   eBay Motors  #9 (permalink)
KB3MMX's Avatar
Shim your FPRV. Don't use a race plug, it won't leave any safe pressure control for the fuel system.
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD
--CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive by KB3MMX Tuning W/ SDP Towing Twins (Billet S475 over Stock)
--SILVERLINE 4" Stainless Exhaust
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
--Airdog II DF200 w/ CAT UHE filter upgrade...etc,etc...
KB3MMX is offline   Reply With Quote Quick reply to this message
Old 01-15-2012, 07:52 PM   eBay Motors  #10 (permalink)
this shim kit is for the 'fuel pressure regulator valve' JUST MAKING SURE
2007 Silverado 3500LBZ 4X4
6.6 Duramax, Allison tranny
200,000 k
235 BFG's
Super Chips Cortex programmer
