Cracked Piston- Sticky Injector? - Chevy and GMC Duramax Diesel Forum
Old 04-26-2012, 07:53 AM   eBay Motors  #1 (permalink)
Bosephos's Avatar
Okay, so some of you know I'm building my motor. Basically I cracked a piston in my LBZ and decided I was going to build it while the motor is out. Here's my thing...I'm a bit worried about 1 of 2 things
The piston that cracked looked washed out, no soot on it like the other pistons...that has me feeling it could have cracked the head and I was getting coolant in there...
My other worry is that the injector for that cylinder may have stuck and caused that to happen. The crack goes straight across the piston...no holes or anything... I had to drive the truck for about 2 miles to get to home with it like this and I'm wondering if it could possibly be from all the fuel spraying on it during that time that washed the soot off... I'm just looking for thoughts... I'll have the heads pressure checked while at the machine shop...I'm just trying to think of other possibilities..
The truck did have some beatings on it of over 600rwhp for daily use... I'm hoping it was just the repetitive abuse on the crappy lbz pistons...
2003 LB7, Built trans, Studded, Airdog 165, EFI Live DSP5, DIamond Eye 4" straight pipe
Bosephos is offline   Reply With Quote
Old 04-26-2012, 08:02 AM   eBay Motors  #2 (permalink)
like a Ninja
guytonLBZ's Avatar
have the injectors checked. IIRC that was part of the reason Chris got his cracked piston
Holton-22 USMC
SOLD "06 chevy 2500HD LBZ 6spd,black and blacked out, CCSB 4X4
Custom Twins, EFI by IdahoROB, built trans W/1058 by ME, 40% nozzles, PPE manifolds & Up-pipes, BD Intercooler, lowered on 20" Fuels, 6000K HIDs,
BIG Thanks to: IdahoRob, Mike L., Suncoast, BD Diesel, PPE, Fuel, S&B, Industrial Injection
Alligator Diesel Performance - 208-777-1977
guytonLBZ is offline   Reply With Quote
Old 04-26-2012, 08:11 AM   eBay Motors  #3 (permalink)
Bosephos's Avatar
How do they typically test them? Just run pressure through it to see if it leaks?
Old 04-26-2012, 08:33 AM   eBay Motors  #4 (permalink)
like a Ninja
guytonLBZ's Avatar
some do that and some bench flow them. bench flow is typically the best. IMHO if you cracked a piston and its a possible that its due to the injector id replace all 8. specially if its going into a built motor.
Holton-22 USMC
Old 04-26-2012, 08:49 AM   eBay Motors  #5 (permalink)
Bosephos's Avatar
Yeah...it's just a lot more money for another set though when my 60% overs will carry me to the hp mark I want...If I do end up buying more I'm going with 100% over
Old 04-26-2012, 09:03 AM   eBay Motors  #6 (permalink)
like a Ninja
guytonLBZ's Avatar
if anything jus by new stock injectors and swap the nozzles
Holton-22 USMC
Old 04-26-2012, 11:00 AM   eBay Motors  #7 (permalink)
Bosephos's Avatar
Special tools required for that?
Old 04-26-2012, 11:10 AM   eBay Motors  #8 (permalink)
Clarke's Avatar
i cracked a piston becasue i had 3 bad injectors.
here is a pic.
Welcome to Facebook - Log In, Sign Up or Learn More
2009 CC/SB/ LMM EFI live, Fass, EGR blocked, braced, and a few more odds and ends
"Explicit Content" 2006 CC/SB/ LBZ- Sled pulling truck. shooting for 700+ hp t
Clarke is offline   Reply With Quote
Old 04-26-2012, 11:12 AM   eBay Motors  #9 (permalink)
SickLB7Crenshaw's Avatar
no just need a 1/2 socket, a vise and a torque wrench. Becareful not to loose the lil puck (its tiny) when u pull the nozzle off the injector.
05' LLY 12.41 @109.9
Blake
SDP Twinz, 40% overs, EFI-Live Props- Idaho Rob, Stage V trans, BT lock up box
4'' Exhaust, Airdog, Traction Bars, Built Front End,
Big Thanks to Dustin, Idaho Rob, and Scott
01' LB7 13.5@97
EFILive by me, Grade C HG, ARP studs,
4 in duals, S@B intake, Airdog, PPE boost valve, BT lock up box on stock trans
SickLB7Crenshaw is offline   Reply With Quote
Old 04-26-2012, 11:16 AM   eBay Motors  #10 (permalink)
That One Guy
WisconsinHick1's Avatar
Yeah the injector was jacked up on Chris's truck.
Like everyone has said test the injectors.
I have a set of LB7 pistons for sale that would go good in that motor.
Mods: A little of this a little of that
Built With Help From Some Great Friends and Sponsor Jags Pro Truck Shop!
