code p0087. - Chevy and GMC Duramax Diesel Forum
Old 05-17-2012, 02:09 PM   eBay Motors  #1 (permalink)
code p0087.
2007 classic duramax having reoccuring low fuel rail pressure code p0087. All reg maintenance performed by dealer. Fuel filters pump injectors have been done plus after market fuel rail pressure releas valve replaced. Still getting codes while towing. What should i do now
tadkins is offline   Reply With Quote Quick reply to this message
Old 05-17-2012, 02:11 PM   eBay Motors  #2 (permalink)
NEDuramax's Avatar
Lift pump
Sent from my ADR6300 using AutoGuide.Com Free App
____________________________________
~2005 GMC Sierra 2500HD CCSB SLT 4x4~
EFI Live DSP5 by Idaho Rob*Edge Insight CTS/Diamond Eye Downpipe/4" Duals (Husker Diesel)*Nicktane Filter Adaptor*LBZ intake/mouthpiece*All emissions bs GONE
NEDuramax is offline   Reply With Quote Quick reply to this message
Old 05-17-2012, 02:23 PM   eBay Motors  #3 (permalink)
Do you mean in tank fuel pump?
Originally Posted by NEDuramax View Post
Lift pump
Old 05-17-2012, 02:55 PM   eBay Motors  #4 (permalink)
eric-satx's Avatar
Good reading material <here>.
2007 LBZ, Tie Rod Sleeves, Pitman & Idler Arm supports, Pump Rub fix, Bilstein 5100s , Cognito UCAs, N-Fabs, Cabin Filter mod, Delayed Blower Module to dry evaporator, and a Power Steering cooler)
2006 Jetta TDI (daily driver)
eric-satx is online now   Reply With Quote Quick reply to this message
Old 05-17-2012, 07:22 PM   eBay Motors  #5 (permalink)
Super Moderator
jc1843's Avatar
Moving to LBZ-- truck runs
Chevy 04.5 LLY, 2X, shell, XDR, MikeL Heavy duty up-grade, 6spd, TransGo, deep pan, de-badged, 65 Gallon replacement Aero tank, LBZ-mp, Kennedy pump, shimmed, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags, custom grille, fender vents, HD trans cooler- Curt front hitch, footwell lights, load lights, Studs, head gaskets.--- Jerry
jc1843 is online now   Reply With Quote Quick reply to this message
Old 05-21-2012, 05:12 PM   eBay Motors  #6 (permalink)
Code P0087
I'm having the same issue on my 07 classic. I installed a FASS system and that helped for a little while but wasn't the fix. Basically what is happening is the Bosch CP3 (injection pump) uses the vacuum from the engine to get fuel from the tank to the pump. This has worked for a lot of people towing these trucks on a regular basis, for some reason some just fail sooner than others. I read the article that eric-satx suggested and suppose if you catch the problem soon enough, replacing a collapsed fuel line would be a quick and easy fix. Installing a lift pump to create positive pressure to the injection pump would be the first route I would take. It can even make a weakening pump feel like it has new life. It cured my woes for about 15k miles and she's throwing the P0087 code again. There is a pressure relief valve that could be failing before you just throw parts at the truck. If the lift pump doesn't help your probably in for a hefty shop bill (injection pump or injectors) but look at the bright side... when things break or fail just start upgrading! Good luck!
dmawalkermower is offline   Reply With Quote Quick reply to this message
Old 05-21-2012, 08:47 PM   eBay Motors  #7 (permalink)
0rion's Avatar
just replaced the hose on my buddies truck that was throwing the 0087 last summer while towing. When we got the hose off it was pretty obvious it had a soft spot in it. I just can't see his issue being anything other than that. With 2 fingers you had to put very very little pressure on it to get it to collapse. Only took about 20 minutes to do and a few minutes of that was having to crawl out from under the truck and get another beer or two.
06 Silverado LBZ ecsb-4" straight exhaust 90HP tow tune with efilive
98 Firebird Formula-heads/cam and everything under the sun.....11.80's at full weight with more left in the car
0rion is offline   Reply With Quote Quick reply to this message
Old 05-22-2012, 09:10 PM   eBay Motors  #8 (permalink)
chevypower's Avatar
My P0087 thread
06 Lbz reg cab 3500 4x4... 4 in. straight, egr block plate, finger stick, air dog 100 and fprv shim ... I have efi live v.2 using to data log and clear codes.(I have also done the race valve did not work) TRUCK IS NOT TUNED STOCK SETTING
2013 4 Dr. 4x4 LTZ
chevypower is offline   Reply With Quote Quick reply to this message
Insurance
