lbz mpg??? - Page 13 - Chevy and GMC Duramax Diesel Forum
Old 01-06-2013, 08:41 AM   eBay Motors  #121 (permalink)
it stinks and whistles :)
Brennan's Avatar
Originally Posted by loanman View Post
I am confused? you are saying the gear ratio between a 3/4 ton and a 1 ton is the same? what would the gear ratio be then?
Every dmax has 3.73 ratio
06 lly,
Efi From ATP trucks,
5" straight pipe, egr blocked, cognito ucas,
rare parts gen2, bilstein 5100s, all season brace,
merchant pump rub fix, drp trans cooler lines,
air dogII 165
Brennan is offline   Reply With Quote Quick reply to this message
Old 01-06-2013, 08:42 AM   eBay Motors  #122 (permalink)
There both 3:73's from all the research I've done.
Beastly Build
LBZ Drag Racing
2006 GMC LBZ 4x4 CC/SB
________________
Go Fast Parts
1/4 Mile 13.226@101.99
1.793 60'
2014 GMC Sierra 1500 All Terrain Slt
DMAX STORE
DaJokr is offline   Reply With Quote Quick reply to this message
Old 01-06-2013, 09:07 AM   eBay Motors  #123 (permalink)
very interesting. I come from a Ford and Dodge background where almost all 1 ton dually's are 4:11 geared.
I wonder why Dmax are all 3:73's
loanman is offline   Reply With Quote Quick reply to this message
Old 01-06-2013, 09:15 AM   eBay Motors  #124 (permalink)
LHN...We ARE the Joneses
When you've got abundant power at 3.73 for pulling grades, why change a good thing? All Dmax HDs from the beginning (2001) are 3.73 from the factory. Only the gasser HDs were 4.10 rears. Newer model gassers now offer both rears.
Hook'em_Horns! is online now   Reply With Quote Quick reply to this message
Old 01-24-2013, 08:59 PM   eBay Motors  #125 (permalink)
Tonkatoy77's Avatar
I don't understand how so many of you guys get such good mileage. Makes me wonder if my truck and everybody I personally know with duramax pickups have something wrong with them. The tires on my pickup are about 36" tall and the best I have ever got is 17 mpg. I went on a camping trip one time pulling a 30' camp trailer at about 8,000 lbs and I drove 1000 miles round trip. I used exactly 100 gallons of fuel on that trip. My math says 10 mpg. I have a friend with an LB7 02' 1 ton that does hot shot loads for a living and he gets 8 mpg average. My brother has a bone stock 06' LLY and he gets 15 mpg average. I am confused.
07' Chevy Silverado LT3 ccsb LBZ. 8" Bulletproof lift kit(junk), Fox shocks, EFI Live by Kory, Edge CTS Insight, 4" Silverline downpipe back exhaust, PPE FPR shims, PPE fuel rail fitting, pcv reroute, resonator plug, Transgo jr, S&B Intake, Amp steps, 20" XD Racing wheels, 36" Goodyear Duratrac tires, Air Lift rear air bags with wireless compressor, billet grill, debadged, Caddy gauges.
77' Ford F-250 factory highboy. 460, hooker headers, 3" flowmaster exhaust, MSD ignition, Comp Cam, Edelbrock high rise intake, Holley 750 cfm double pumper carb, Holley fuel lift pump, Autometer gauges, 3" lift kit, 38" Toyo tires, 18" Weld wheels.
Tonkatoy77 is online now   Reply With Quote Quick reply to this message
Old 01-24-2013, 10:07 PM   eBay Motors  #126 (permalink)
I get about 17mpg hwy, 12-13 city on winter fuel. Since using fuel additive numbers have gone up, but only by ~1mpg. My LBZ is stock, no lift, and is on 235/85r16 toyo wlt1 winter tires, stock alloys. 100km/h on the highway, being non-aggressive.
I'll post up if there's a change when I get rid of my current fuel filter (12% and falling fast)
Beastly Build
LBZ Drag Racing
________________
Go Fast Parts
1.793 60'
DMAX STORE
Old 01-24-2013, 11:11 PM   eBay Motors  #127 (permalink)
73guna's Avatar
You really have to take mpg threads with a grain of salt.
Everyone has different driving habits/styles, so mileage varies greatly.
Some have their truck tuned/programmed some dont.
Some are pretty accurate with their numbers some arent.
Those 36" tires are probably hurting your mpgs. Is your speedo calibrated for the taller tire?
Mitch
2007 Chevy LBZ, lt3, ccsb, white, tan leather buckets, 265/75-16 Nitto dura grapplers, MBRP 4" SS.
http://i18.photobucket.com/albums/b1...guna/010-1.jpg
http://i18.photobucket.com/albums/b1...guna/004-2.jpg
1973 laguna 489ci, 600hp, ford 9" 3.89 gears, 400th.
http://i18.photobucket.com/albums/b1...a/e7c3c186.jpg
73guna is offline   Reply With Quote Quick reply to this message
Old 01-25-2013, 02:48 AM   eBay Motors  #128 (permalink)
Snowman741's Avatar
So far through the winter her in MN my truck is still on the 265s and my mpg with the efi live tunes have been 14.8-15.5 thats running the 100hp performance tune. I lose about 1.5mpg running the 150hp race tune and lose about .6mpg running the 75hp economy tune.
So for leaving my truck idle for about 2 hours a day in -20 to 20 temps and doing mixed driving for 45miles every day I'm not too disapointed.
Thats all hand calculated by gps and dash. Idaho Rob got my ODO set perfect for the 265s, its only been off by 1/10 of a mile per tank.
2006 LBZ XC LB 4x4 - Pypes 3" Down Pipe leading into Diamond Eyes 4" Turbo Back Straight Pipe Duals w/ EGR Blocked and PCV reroute
- EFI Live DSP5 key lock from Idaho Rob w/ Edge Insight CTS & EGT Probe
- Trans Go Jr, Fuel Rail Shim Kit, Banks Hotside IC Pipe, Fass Titanium 150 w/ heater element
- Tuff Country 4" Lift/Leveling kit w/ Caltracs and ATP Tierod Sleeves
- American Outlaw Armor 16x8 wrapped with Discoverer ST Maxx 285/75 R 16 w/ 1.5" Rear Wheel Spacers
2004 Excursion 6.0 Powerstroke 4x4- ARP Head Studs / Sinister EGR Delete / Coolant Filter / 4" Diamond Eye turbo back straight pipe / 6.4 banjo bolts / blue fuel pressure spring / Fass Titanium 95 w/ fuel heater / SCT Livewire TS w/ custom tunes
Snowman741 is offline   Reply With Quote Quick reply to this message
Old 01-25-2013, 04:24 PM   eBay Motors  #129 (permalink)
Tonkatoy77's Avatar
I am not complaining about my mileage, I didn't expect 20 mpg when I have a pickup with 36" tires on it. I just think that people are adding a couple mpg's to their actual miles. When my pickup gets 10 mpg with 36" tires pulling an 8000 lb trailer and I see people posting 19 mpg pulling 18000 lbs, it makes me wonder.
Old 01-25-2013, 10:59 PM   eBay Motors  #130 (permalink)
73guna's Avatar
lol, yeah I know what you mean.
There are some pretty crazy mpg claims.
I remember one guy took a picture of his DIC and it read 30+mpg.
He got flamed pretty hard by the guys here.
Mitch
Insurance
