are there any major problems with the lbz - Chevy and GMC Duramax Diesel Forum
Old 09-13-2012, 06:48 PM   eBay Motors  #1 (permalink)
2007lbz4x4's Avatar
i just bought an 07 lbz and i really dont know a thing about cheveys because im a ford guy
2007 lbz bone stock for now
from montrose sd
2007lbz4x4 is offline   Reply With Quote Quick reply to this message
Old 09-13-2012, 06:52 PM   eBay Motors  #2 (permalink)
Slave to the Interwebs
Johnasara's Avatar
My only problem is I cannot drive it enough. I am tied to the LMM during the week and it is heavy. My LBZ is just flat fun to drive
WORK RIG
2014 3500 CREW,DUALLY, LML, HARBOR 9' UTILITY BED Bone Freakin Stock
Johnasara is offline   Reply With Quote Quick reply to this message
Old 09-13-2012, 07:01 PM   eBay Motors  #3 (permalink)
SST 1953's Avatar
All I can say is you won't be a ford guy for long! Stock power is awesome, but tuned power is unbelievable. Block the EGR, get an aftermarket exhaust, and EFI live custom tunes and hang on. It's addicting so save your pennies, the power gets better and the mods get more expensive after that.
2007 CCSB LBZ.
EFI live DSP 5 by Rob @ ATP
EGR blocked, PVC reroute
AirDog II 165
TransGo Jr/pump rub mod
Firestone bags
4" MBRP
Edge Insite CTS w/ backcam
Cognito W/Bilsteins
69 Camaro S/ST-S/Gas
SST 1953 is offline   Reply With Quote Quick reply to this message
Old 09-13-2012, 07:05 PM   eBay Motors  #4 (permalink)
86burgandyss's Avatar
Maintain it and enjoy!!! They will go a long way!
Rodger
07 classic crew cab long bed 2wd 2500 700,000 miles BITCHES!!!!!!!!!
Rotella T oil. Have replaced entire fuel system, sending unit to injectors, lines included, Waterpump, hydro boost, besides that truck is factory original except ujoints and brake pads 3.73 rear, stock tire size bully dog , 5 inch turbo back, with 6 inch tip.
Titan 55 gallon aftermarket tank 115 gallon auxilary tank
5% tint on all windows, and "eyebrow" on front
86 burgandy Monte Carlo SS
86burgandyss is online now   Reply With Quote Quick reply to this message
Old 09-13-2012, 07:08 PM   eBay Motors  #5 (permalink)
2007lbz4x4's Avatar
I will allways be a ford gas truck guy and ive always liked dmaxes and i still have my ford gas but it sits a lot now lol
from montrose sd
Old 09-13-2012, 07:56 PM   eBay Motors  #6 (permalink)
b14
best thing i think ive herd someone say about a furd.. sitting
2010 2500 ccsb
dpf delete - egr blocked - cheap pcv re-route
efi live tuned dsp5 - by rob!
4" Diamond eye duals
afe intake with pro dry 2
ride rights
edge insight cts w/ egt probe and two backup cameras
Dirty Loud and Proud
b14 is offline   Reply With Quote Quick reply to this message
Old 09-13-2012, 08:11 PM   eBay Motors  #7 (permalink)
Hang it!...Fire!
TDIpowered's Avatar
ill give you that i do like the way ford gas v8s sound. not in trucks though plus i would take my old 6.0 over a pussy 5.4 anyday
Max - 07 LBZ ECLB LOWERED!
TDIpowered is offline   Reply With Quote Quick reply to this message
Old 09-13-2012, 08:12 PM   eBay Motors  #8 (permalink)
Banned
LBZ's crack pistons
Hondarider552 is offline   Reply With Quote Quick reply to this message
Old 09-13-2012, 08:45 PM   eBay Motors  #9 (permalink)
2007lbz4x4's Avatar
5.4s are good i have one which i drove this week over the dmax
from montrose sd
Old 09-14-2012, 08:28 PM   eBay Motors  #10 (permalink)
KB3MMX's Avatar
Originally Posted by Hondarider552 View Post
LBZ's crack pistons
X2 ^^^
LBZ's have the strongest rods of all the Duramax engines, leaving the pistons as the weak link at high horsepower.
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD
--CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive by KB3MMX Tuning W/ SDP Towing Twins (Billet S475 over Stock)
--SILVERLINE 4" Stainless Exhaust
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
--Airdog II DF200 w/ CAT UHE filter upgrade...etc,etc...
KB3MMX is offline   Reply With Quote Quick reply to this message
