Old 04-25-2007, 07:05 PM   eBay Motors  #11 (permalink)
Mike L.'s Avatar
I suspected that you drove pretty slow. The problem is a hard working converter with no airflow through an undersized cooler ( there is no airflow under 35 mph) and 245 psi constant pressure= a lot of heat. The factory cooler does not have the capability of bringing those temps back in line even after hyway driving because of its size. Use TowHaul as much as possible, synthetic fluid both engine and trans. 4 inch exhaust will help also.
Mike L. is offline   Reply With Quote
Old 04-27-2007, 05:46 PM   eBay Motors  #12 (permalink)
cs-john's Avatar
Mike L. Do you have a link with the information on your cooler, like price and installation hints?
2006 LBZ CC
PPE Xcellerator
Pyrometer
Bilstein Shocks
4" MBPR Catback
Firestone Ride Rite Air Bags
Bushwacker Pockets
Escalade Door Handles
Billet Grill
305 Cooper on Hilo's
cs-john is offline   Reply With Quote
Old 04-27-2007, 07:12 PM   eBay Motors  #13 (permalink)
Mike L.'s Avatar
PM me your email address and I will send you pictures. Install on an '06 is 2 bolts and snap the cooler lines in like factory. No fuss. Cooler is available from vendors on this board.
Old 04-28-2007, 07:12 AM   eBay Motors  #14 (permalink)
Originally Posted by cavenderlbz View Post
do you guys usually get that hot when towing heavy or do i have some sort of cooling issue?
I agree with Mike. Use synthetic fluid.
I had the same concern. For me, as soon as i added cooling capacity in the form of an engine oil cooler with the air dam, my transmission temperatures lowered. My fan stays off now, where before, it ran nonstop. I love the extra 2 mpg. I moved it to my LBZ, and now I will tow only with it.
I really just like the idea that I improved a number of things at once, with one deal, without removing anything that is stock.
04 LLY SRW SB
06 SRW SB
EFILive all conditions no smoke 100 HP tune, exhaust, TD-EOC, alternative stock Cold Air Intake.
TravelswithCharly is offline   Reply With Quote
Old 04-28-2007, 10:44 AM   eBay Motors  #15 (permalink)
Mike L.'s Avatar
Smells like killerbee to me.
'04 Chevy Duramax CCSB 4X4
