seriously?? 2 thermostats?? - Chevy and GMC Duramax Diesel Forum
Old 11-19-2012, 03:08 PM   eBay Motors  #1 (permalink)
cessna150's Avatar
i went to buy a thermostat for my truck, and was told they dont keep them in stock!!!! there has to be a 1000 of these trucks in my little neck of the woods...so i said get me one, and was told there are two...really?? where does the other one go?
2006 1 ton 4X4 w/t..but i do have a ranchhand front bumper and hummer wheels!!
cessna150 is offline   Reply With Quote
Old 11-19-2012, 03:21 PM   eBay Motors  #2 (permalink)
Offical LB7 "Tech"
01 D_Max's Avatar
There are 2. They are both in the same spot under the upper radiator hose. One opens at 160 and one at 180.
-Aaron-
2001 GMC Sierra 2500HD, Limited Edition, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, BATMO, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler- Wastegate, FASS 150, LBZ FPR, Shimmed FPRV, Built Trans, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires,
MANY More extras inside...
01 D_Max is online now   Reply With Quote
Old 11-19-2012, 03:36 PM   eBay Motors  #3 (permalink)
battlegraduate09's Avatar
I hope you were sitting down when you had this conversation. Sounds like you were dumbfounded and learned something new
Josh
04 LLY CCSB 4X4
battlegraduate09 is offline   Reply With Quote
Old 11-19-2012, 04:02 PM   eBay Motors  #4 (permalink)
cessna150's Avatar
garcia 01!!
Old 11-19-2012, 04:24 PM   eBay Motors  #5 (permalink)
Offical LB7 "Tech"
01 D_Max's Avatar
-Aaron-
Old 11-19-2012, 04:27 PM   eBay Motors  #6 (permalink)
KB3MMX's Avatar
Lol
Ham Radio= Global communications without airtime fees
My Antenna-SteppIR
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo
--SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
KB3MMX is offline   Reply With Quote
Old 11-19-2012, 05:21 PM   eBay Motors  #7 (permalink)
Banned
Stats are 180 and 185
Old 11-19-2012, 05:33 PM   eBay Motors  #8 (permalink)
TwoFortySX's Avatar
Yep. There are two under there.
'03 ECSB Silverado 2500HD
aka Allie Diesel
EFILive Tuning by Kory Willis - Edge CTS Insight w/ Pyro - PPE Boost Valve - MBRP 5in exhaust - Modified Intake w. K&N Filter
TwoFortySX is offline   Reply With Quote
Old 11-19-2012, 05:54 PM   eBay Motors  #9 (permalink)
Offical LB7 "Tech"
01 D_Max's Avatar
is that what it is??? I mis-remembered i guess.
-Aaron-
Old 11-19-2012, 05:57 PM   eBay Motors  #10 (permalink)
07.5 LMM's Avatar
why exactly do they use a double thermostat system? I heard this before but never really figured out what the deal is.
07.5 LMM CCSB LT. A couple mods.
07.5 LMM is offline   Reply With Quote
