| 06-07.5 LBZ & LLY Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |
| Junior Member Join Date: Sep 2012 Location: Corpus Christi Texas
| Truck feels like it's under a load and not wanting to move Well last night I did the LED cluster swap and when I went to leave this morning for school it feels as if I'm hooked up to huge loaded trailer but it will still idle forward as usual. I thought it was in limp mode so I hooked a buddy's insight up and cleared all the codes but it still isn't working right. It feels like the brakes might be locked up but how could they be when it can still idle forward easily? Any one have any ideas?
__________________ 2007 GMC, LBZ, EFI live, air dog 150, transgo jr, cognito 1'' block, rare parts tie rods, cognito supports, bilstein 5100's, 5'' MBRP exhaust, LED cluster, denali headlights, led tail lights, color matched front end 2003 Cummins leveled on 35'' toyos, valair dual disk clutch, superchip - biggest POS ever-SOLD 1999 Jeep Cherokee 6.5'' lift, 4.56 gears, long armed and a beast - damn I miss it-SOLD |
| Alligator Performance ![]() | you can drive the trucks with out the gauge cluster, changing leds isnt going to change anything on how it drives. Are you getting any codes?
__________________ |
| It's showing U1026 which is a loss of communications with the transfer case control module
| It also says it's in 4 low and it won't go back into 2wd
| Duramax Lifetime Supporter Join Date: Apr 2012 Location: Casa Grande, Az
| Check the ignition fuses...that code is for transmission module just check all the fuses
__________________ 2012 GMC 2500 SLT 4x4 H&S minimaxx, MBRP downpipe back SS duals, Insight CTS w/backup cam, Fass HD150, PPE rear diff cover, Amsoil front to rear w/by-pass Cognito 4-6 NTBD w/idler/pitman braces, a-arms, Monster energy 18x9 w/BFG KM2s 35x12.5, Recon smoked cab lights Titan 57 gal saddle tank, linex color matched bedliner w/kevlar, Trekstep bed steps x2, RBP rail steps |
| I just checked them all and the only ones that aren't working are BTSI and CRNK. The fuses looked good but I replaced them anyways and they're still not getting power.
| Sorry you were rt., transfer case module. Looked up on Identifix, said ign. fuses(including large 40a) but that guy had a no start also, and brake fuse. does the trans gear indicator light up? thats all i have man
| Alligator Performance ![]() | Is your transfercase solenoid making any noise like its trying to change over then just quit? Its pretty common for the transfercase solenoid to go out after a while on these trucks.
| The only indicator light is the battery light and the check engine light.
| I don't hear anything but I'm not really sure where thats located.
