What gear for towing 6000lb - Chevy and GMC Duramax Diesel Forum
Old 11-20-2012, 10:20 AM   eBay Motors  #1 (permalink)
What are you guys using running 70-75 on the hilly interstates? 5th or 6th. If using 6th does it down shift much. I haven't bought one of these trucks yet but I have drove a LLY and loved how it never down shifted with my boat on the interstate. Just wondered if the 6 speed will be the same.
champ210 is offline   Reply With Quote
Old 11-20-2012, 01:51 PM   eBay Motors  #2 (permalink)
Depends on how much throttle input your asking for when your going up those hills. Tow/haul mode is usually pretty spot on with downshifts and up shifts.
2006 Chevy 3500 HD Crew Cab dually.
Straight pipe MBRP 4" exhaust
PPE level 2
PPE air box mod
Stock tranny (for now)
04LB7 is offline   Reply With Quote
Old 11-20-2012, 02:37 PM   eBay Motors  #3 (permalink)
LHN...We ARE the Joneses
For that small amount (6k lbs), hit T/H, set the cruise and forget 'bout out.
Selective lock out and running in 5th benefits only comes into play with 12k lbs and above.
Old 11-20-2012, 04:08 PM   eBay Motors  #4 (permalink)
I do not recommend towing at 75. But if you do just put it in D Tow Haul on and let the Allison do its job. With Tow Haul on it will not be shifting very much.
lavarock is offline   Reply With Quote
Old 11-20-2012, 04:14 PM   eBay Motors  #5 (permalink)
jevanb's Avatar
it will shift to 6th above 60mph in tow haul, at least mine does, if I stay at 55 it will not go into 6th unless I take it out of TH.
AD2, DP/full exh, blocked, nicktane, tgo,DSP5 from rob, gauges,bagged/compressor, reroute, some other stuff
Superglide hitch
2012 Wildcat 344QB
jevanb is offline   Reply With Quote
Old 11-20-2012, 04:27 PM   eBay Motors  #6 (permalink)
Dmaxftw's Avatar
I dont have the experience pulling with a dmax yet since i haven't purchased mine yet but since your all saying that the allison doesn't shift much with T/H on is that really serious? even in the hills and what not? my 07.5 1/2 ton with the stupid freaking 4 speed tranny they put in it shifts like a compulsive ocd freak with tow haul on and my cruise set. And i have done this with 4-5k lbs behind me and with just 1500 lbs behind me it makes no difference i hate the half tons 4 speed its sooo annoying in the hills. I believe the tranny i have is the 4L60E or something to that effect.
2007.5 Sierra 1500 CCSB
Iron Bull Bumpers
PIAA Fog lights and reverse lights
BFG M/Ts
Waiting for the New body style to release before i purchase my new Duramax.
Dmaxftw is offline   Reply With Quote
Old 11-20-2012, 05:30 PM   eBay Motors  #7 (permalink)
jevanb's Avatar
Originally Posted by Dmaxftw View Post
your all saying that the allison doesn't shift much with T/H on is that really serious? even in the hills and what not? .
yep it will only down shift if the computer thinks it needs to, I have a rather large/high bridge I cross and I can almost make it to the top at 65mph in 6th with the trailer in tow. I had a 04 2500HD with the 6.0 gas and it was always hunting gears. but since we have soooo much power it is not all used up. the only reason I shift to 5th is if the egt`s get high but that was before EFI
Superglide hitch
2012 Wildcat 344QB
Old 11-20-2012, 09:54 PM   eBay Motors  #8 (permalink)
Lawman's Avatar
Egt's and fuel mileage will be better in 5th gear.
2006 white RCLB 2500hd 2wd, LBZ, 4" turbo back, k&n intake with Amsoil air filter, Diablosport Predator, Glowshift boost & egt, B&W Turnover Ball.
Lawman is offline   Reply With Quote
Old 11-23-2012, 08:14 AM   eBay Motors  #9 (permalink)
right on the head
EXACTLY what you are describing is why I bought a Dmax. I had an 07 1/2 ton with the 5.3 - - It would not tow my 5000# boat at interstate speed PERIOD . Flat level at 65 was about the best it would do if you feathered the throttle. ANY attempt to accelerate or even the slightest grade and it would shift back down into 3rd - worse yet a big hill and it would go back to second.
I replaced that truck with a 2500HD with the 6.0 and 4:10 rear axle (also the 4l80E transmission - a HUGE improvement, Cept that the gas burner will not pass a gas station without stopping in for a drink.
2006 GMC 2500HD SLT CCSB 4WD, K&N, Autocal DSP5,RDS Toolbox/Transfer Tank, Nicktane Cat Filter, PCV Reroute, Toyo 285 AT II's, FASS 150 HD, ADP Sump, EGR Block, leveled.
CapnDean is offline   Reply With Quote
