| 06-07.5 LBZ & LLY Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |
| Junior Member ![]() | That is what I am saying..... Add a filter....but also add a small 8-10 psi inline pump. The plan being to light that pump any time the engine is running. Understand that should it die.....I would likely have fuel delivery issue.
__________________ 2006 GMC 2500HD SLT CCSB 4WD, K&N, Autocal DSP5,RDS Toolbox/Transfer Tank, Nicktane Cat Filter, PCV Reroute, Toyo 285 AT II's, FASS 150 HD, ADP Sump, EGR Block, leveled. |
| Senior Member Join Date: Oct 2009 Location: Colorado
| Throw a raptor and a nictane adapter on and for under $500 you're set. Sent from my iPhone using AutoGuide.com Free App
__________________ 04 lb7 285/75/16 BF Goodrich A/T, 4" Exhaust and 5" Tip Fumoto Valve PPE High Idle/Valet Switch Bilstein shocks Pro Comp Leveling kit Air Ride 5000 bags Nictane Cat Adapter 1R-0750 Filter DSP2 By Nick, www.duramaxtuner.com |
| | eBay Motors #13 (permalink) | |
| Junior Member Join Date: May 2006 Location: Idaho
| Quote:
http://mallory-ignition.com/media/in...0_140_0003.pdf More on Jegs but all with 3/8". 140 Gallons per Hour, what other volume are you measuring? These guys aren't having any problems yet. Great lift pump for the $$$$$!!!
__________________ 2006 Chevy Duramax LBZ CCSB, LT3, fully loaded, leather, bose, sunroof, MBRP 4 inch exhaust, AFE intake Stage 2, suncoast V, Edge juice w/***, gauges, EGR blocked, 6-inch lift, H2's w/ BFg AT 35's | |
| Senior Member Join Date: Feb 2012 Location: Dodge City, KS
| You can solve the issue of a failed pump with a manual valve and two t-fittings or a check valve for it to work automatically. This is the setup I used and tested it with my lift pump fuse pulled and it worked flawlessly.
__________________ 2003 Silverado 2500LS CCSB 4x4 ZF6 EFI live with DSP5, Nicktane Aux Filter adapter and Filter head adapter with CAT water separator and 2 micron filter, Raptor 150 lift pump with check valve bypass, MA Engine Mounts and Trans Mount, MA Pump Rub Kit, SBC Dual disc, Straight pipe, Roadmaster active supension, Moog pitman/Idler/Support Bracket, Cognito support kit, Rare parts tie rods, Profab Turbo Horn, Intake heater delete, Kennedy high idle and airbox mod ------------------------------------------ |
| | eBay Motors #15 (permalink) |
| DuramaxForum Veteran ![]() Join Date: Mar 2012 Location: Casper, Wyoming
| The orifics in the Holley are only 5/16" in the regulator to bring it down to 8-10 lbs, the Mallory regulator is still 3/8". You can run the Holley pump with a different regulator to get the same volume, but why. The Mallory will also last 10 times longer. If you plan on running it without the regulator, so long CP3, it isn't going to last long. Holley makes good carbs, not good fuel pumps.
__________________ 2007 CCSB LBZ. ![]() EFI live DSP 5 by Rob @ ATP EGR blocked, PVC reroute AirDog II 165 TransGo Jr/pump rub mod Firestone bags 4" MBRP Edge Insite CTS w/ backcam Cognito W/Bilsteins 69 Camaro S/ST-S/Gas |
| | eBay Motors #16 (permalink) |
| Why the hell would they down side it 5/16"? I guess I'll quit trying to be a cheap ass and just spend the money on a good pump. Searching some more.
| | eBay Motors #17 (permalink) |
| I found out the hard way running carb bowls dry about 1200ft down the track a few years ago. A friend gave me some advice and tried a Mallory 140 he had and I picked up 3 mph and 2 tenths. I also had a Holley on my 84 1ton 454 until then and it went bye bye. Much more power with the Mallory. For the money I would go with the Air Dog 165 or Fass systems for the Duramax.
| | eBay Motors #18 (permalink) |
| Junior Member ![]() | So much good information here. I am not looking for more hp or any fancy tune. I am simply trying to provide cleaner fuel to the motor. Recognizing that the factory set up is sufficient for a factory tune, my fear is that by inserting another filter (of which I have plenty lying around....free...marine debris, stuffed in nooks and crannies on my boat) I will possibly strain the injection pump unduly. My plan is to plumb in a filter close to the tank, install a 10 micron element - and suck the fuel through it with a small 12v pump. It will probably feed pressure to the injection pump at about 8PSI give or take. This type pump will probably move maybe 25 gallons per hour. I may plumb a bypass to it so that should it quit on me I can bypass it and the filter. Guys these lil pumps are about $20 and I have never had a problem out of one other than old age. I like them for priming the filters after a filter swap because all you do is spin on a filter, leave it a tad loose, run the pump and when the filter is full and begins to leak, snug it up. Viola....no fuss no either, no cracking injectors etc...
