Please help! Trouble starting - Chevy and GMC Duramax Diesel Forum
Old 12-01-2012, 05:10 AM   eBay Motors  #1 (permalink)
EFIdmax06's Avatar
I've been having a starting issue with the truck. It happens mostly (but not limited to) early in the morning. Ill turn the key up, wait for the glow plugs, and then when I try to start, click click click... Usually if I let it hit the starter for long enough it will turn over like normal. Here's what's strange, for two weeks now, I was sure the issue was resolved as I replaced both batteries and the starter. I'm going to double check my connection to the starter in a second. Also on the starter, I noticed the bracket thing on the solenoid seems very loose, not sure if thats right or not. I'm just very frustrated with it at the moment and it seems I'm running out of options. Please help guys, my fear is some crazy electrical issue.
2006 white LBZ 4x4 dually. S&B intake, resonator box delete, 4'' straight exhaust, trans-go jr, PPE shim kit, ADII 165, PCV re-route, EFI live tunes by Idaho Rob, 6'' lift, 35 12.50
Previous: 2001 LB7 grey 4x4. Straight exhaust, EFI live, leveled, 18'' mazzi hulk wheels, 33 12.50
EFIdmax06 is offline   Reply With Quote
Old 12-01-2012, 05:45 AM   eBay Motors  #2 (permalink)
EFI'd and lovin it
Johnasara's Avatar
The " Click, Click, Click" usually means there is a loose connection somewhere.
EXHAUST,EFI LIVE,DSP5,TPTUNED BY KORY WILLIS,S&B COLD AIR INTAKE
WORK RIG
O7.5 3500 CREW,DUALLY, LMM, ROYAL UTILITY BED...STOCK......ISH
This is not only your forum you have to share it with over 80,000 others
Old 12-01-2012, 07:33 AM   eBay Motors  #3 (permalink)
EFIdmax06's Avatar
The small wire on the solenoid is tight however, the pedestal it bolts to is very loose feeling
Old 12-01-2012, 09:27 AM   eBay Motors  #4 (permalink)
Baby maker extraordinaire
ty_LBZ's Avatar
Check your ground wires, dmax requires lot of amps to turn it over. My money is on a loose/missing ground jumper.
2006 Chevy LBZ 4WD CCSB Resonator sealed. plugged & sticked. re-routed. shimmed. 4" MBRP cat-back(too much drone). Alligator trans cooler hoses. Transgo Jr. MA pump rub fix. Rare Parts tie rods. Fumoto Valve. Bilstein shocks. AC Delco batteries. Daily driver.
Originally Posted by Thomas Jefferson
"I prefer dangerous freedom over peaceful slavery."
Originally Posted by creekr View Post
"The navy seals didn't kill bin laden it was their guns"... Said no one ever
Originally Posted by Clint Smith
"When seconds count, the cops are just minutes away."
OMG! (obama must go!)
ty_LBZ is offline   Reply With Quote
Old 12-01-2012, 09:36 AM   eBay Motors  #5 (permalink)
ty_LBZ's Avatar
Which part is loose?
Old 12-01-2012, 10:21 AM   eBay Motors  #6 (permalink)
EFIdmax06's Avatar
Basically according to your picture, the very top left where the smaller of the two wires hooks up. The gold colored bracket is shakey
Old 12-01-2012, 10:28 AM   eBay Motors  #7 (permalink)
EFIdmax06's Avatar
It came out of the box that way so I figured I'd leave it alone
Old 12-01-2012, 11:35 AM   eBay Motors  #8 (permalink)
fonzas05's Avatar
I had the same problem. Mine was the wires conecting to the ignition. I like my stearing wheel tilted all the way down. Next time it does that tilt your wheel up and try and start it, if it starts theirs your problem.
fonzas05 is offline   Reply With Quote
Old 12-01-2012, 11:50 AM   eBay Motors  #9 (permalink)
EFIdmax06's Avatar
Thank you! Ill try that
Old 12-23-2012, 01:05 PM   eBay Motors  #10 (permalink)
fonzas05's Avatar
Well mine went into the no start mode again,and this time i would turn the key and nothing. Turns out it was the starter.The dealer told me about the tilt problem, said the wires stretch when you tilt down causing a bad connection.Said he has seen this problem alot so thats were i got that info. Starter cost 520 dollars at dealer installed with warranty.
