ABS activating at slow speed - Page 2 - Chevy and GMC Duramax Diesel Forum
Old 12-05-2012, 05:17 PM   eBay Motors  #11 (permalink)
bearings have no slop
2006 GMC 2500HD SLT CCSB 4WD, K&N, Autocal DSP5,RDS Toolbox/Transfer Tank, Nicktane Cat Filter, PCV Reroute, Toyo 285 AT II's, FASS 150 HD, ADP Sump, EGR Block, leveled.
CapnDean is offline   Reply With Quote
Old 12-06-2012, 02:53 PM   eBay Motors  #12 (permalink)
UPDATE
Replaced both front wheel sensors. ABS light illuminates. Truck stops fine.
Take the new brake sensor out of the left side and put the old one back in, ABS light extinguishes....but now the slow speed abs activate problem returns.
This is driving me nuts! A new master cylinder, two new wheel sensors and a new abs pump and the problem still exists.
The only code thrown on the borrowed ABS code reader was from where we pulled the fuse and disconnected the left wheel sensor and then the right wheel sensor. Once cleared there have been no other codes. (Of course there will be now because the abs light illuminated) but I have to go back to my buddy who has the code reader to see.
NUTS TO ME! (Thank heaven's it is not MY truck....)
Old 12-07-2012, 03:55 PM   eBay Motors  #13 (permalink)
Battlegrad09 gets the prize! Right front wheel bearing.
problem solved....a big thanks to all with the patience to read and help diagnose!
Old 12-07-2012, 05:05 PM   eBay Motors  #14 (permalink)
Had that problem on my truck and my suburban and my sons GMC Yukon front hub and bearing every time!
2006 LBZ EGR BLOCKER, PPE STANDARD,6000W inverter, AMSOIL DUAL BYPASS, ALL AMSOIL FRONT REAR TRANS TRANSFER CASE, BACKUP CAMERA, EDGE CS GAUGES W/EGT PROBE, REMOTE START,PARROT HANDS FREE BLUETOOTH.4"in MBRP EXHAUST/WCAT DELETE PIPE,PCV REROUTE,ALL HEADLIGHT ON MOD.
rvjabo is offline   Reply With Quote
Old 12-09-2012, 07:41 AM   eBay Motors  #15 (permalink)
ieetgluu's Avatar
So how did you come to figure it was the wheel bearing if there wasnt any 'slop'? Just changed it out?
Chad
04.5 4x4 ~123k miles
DE 4", LBZ MP, KoryWillis Go-go Juice, Insight CTS, ADII, 8' Fisher
'If 40 is the new 20, smoke stacks are the new red car syndrome'
Dirtymax this, Dirtymax that...
I like my max's clean
ieetgluu is offline   Reply With Quote
Old 12-09-2012, 09:17 AM   eBay Motors  #16 (permalink)
Buzzard101's Avatar
Mine just started doing the same thing in 4Low, but not in 4High. 78000 miles. Guess I better looking at front hubs.
____________________
06 LLY,CCSS...6 speed Allison...EFI Live by Idaho Rob... ProFab Down Pipe...5" SS MBRP Exhaust...EGR Blocked... PPE airbox mod...Debadged
_____________________
Retired
94 Chev 2500 Excab 6.5 198,000 miles
88 GMC 3500 Excab 6.2 165,000 miles
Need for speed
09 BMW 335xi coupe
Twin turbos
Cobb Tuned
Buzzard101 is online now   Reply With Quote
Old 12-09-2012, 12:37 PM   eBay Motors  #17 (permalink)
#1) I read this forum
#2) We found a buddy with a more advanced code reader.
After replacing the master cylinder, abs pump and both front wheel sensors.... we read the codes while driving (with the better reader) It showed an wheel speed indication prblem on the right front wheel.
We swapped back to the original wheel sensor and got the same code.
Replaced the fron wheel bearing assembly $169 and bang,,,, problem solved.
Otherwise there was no indication that the front right wheel bearing was bad.
It rolled fine, did not stop as you would expect a bad bearing to do. It had not slack or slop in it from side to side.... etc.
Old 12-09-2012, 10:04 PM   eBay Motors  #18 (permalink)
ieetgluu's Avatar
interesting. I believe Im having similar issues on my truck
Chad
Old 01-07-2013, 06:10 AM   eBay Motors  #19 (permalink)
I had the same issue with mine, no slop but changed wheel bearings and my ABS issues were gone.
If you want to be precise you need to watch the ABS signal from each wheel to see which one is the culprit.
MTL_Dmax is offline   Reply With Quote
Old 01-07-2013, 04:10 PM   eBay Motors  #20 (permalink)
Yes to having a code reader that reads the signal for each wheel. That was the final determinator after reading this site and all the wheel bearing comments.
