Got in an accident. - Chevy and GMC Duramax Diesel Forum
Old 12-25-2012, 07:56 AM   eBay Motors  #1 (permalink)
zeke38's Avatar
Got in an accident.
Long story short driving home from walgreens got rear ended at 40-50 mph. And pushed me into the next three cars. Does anyone know if ill be able to buy my truck back if the frame ends up being bent? This is my first accident
Sent from my SPH-L710 using AutoGuide.Com Free App
2006 LBZ. ATS Stage 2 W/ Co-Pilot. EFI Live. 5" diamond eye. Keys. Tierod Sleeves. CenterLink. Gauges.
zeke38 is online now   Reply With Quote
Old 12-25-2012, 07:57 AM   eBay Motors  #2 (permalink)
Banned
Damm, you ok buddy?
It is all gonna depend on who your insurance is thru, but more than likely they will give you the option...
smokinlmm is offline   Reply With Quote
Old 12-25-2012, 08:02 AM   eBay Motors  #3 (permalink)
Jonesin33's Avatar
Sorry bud
Sent from my DROID RAZR HD using AutoGuide.Com Free App
2005 Chevrolet Silverado 2500HD LT3, 6.6 Duramax LLY, 95k miles, EFI Live Idaho Rob, 4in Silverline Turbo Back, AFE Stage 2 Intake, 6in Fabtech, 35 Mickey Thompson ATZ tires on 17 ProComp rims, fully debadged, 10sub 800watts.
Jonesin33 is offline   Reply With Quote
Old 12-25-2012, 08:09 AM   eBay Motors  #4 (permalink)
GUy behind you was flyin. With the water on the ground I'm guessing they were traveling too fast for conditions.
The insurance company will usually give you the option to buy it back. You may need to ask the question though.
Make sure they give you fair value too. They will try to lowball everything they can from the condition of the paint to the miles on the odometer, especially since it's someone elses insurance that should be paying for it since it's someone elses fault.
DON'T TAKE THE FIRST SETTELEMENT!!!!! If you don't feel good about it, talk with your insurance company and try to get some help.
2008 2500HD CCSB
EFI Live by Idaho Rob Coddens Adrenaline Truck Performance
4" turbo back MBRP by Pat at BT Diesel
lifted with 35s.
Originally Posted by oleblack03
Every time I hear someone say that their half-ton will tow as much as my 3/4 ton I just compare it to having sex with your cousin.......it can get the job done.....but the longterm effects can really F%$ something up
Originally Posted by ty_LBZ View Post
A firefighter inherits a bad situation too, but you don't see him throwing gas on the fire...
Jhill is offline   Reply With Quote
Old 12-25-2012, 09:25 AM   eBay Motors  #5 (permalink)
your truck aint hurt. Got pictures of the poor sap that hit you? That trailer hitch ball being folded up under there tells me that the fellow that hit you must be ailing.
In answer to your original question: You have the right to keep your truck and collect the difference between the junk value and the pre accident value.
You are not entitled to "profit" from the accident...but most folks savvy enough to buy back do somewhat. From the pics though, I doubt you are totalled.....your truck worth a minimum of 20K unless super high miler. I see maybe 6K at the body shop. But again....I could be wrong.
2006 GMC 2500HD SLT CCSB 4WD, K&N, Autocal DSP5,RDS Toolbox/Transfer Tank, Nicktane Cat Filter, PCV Reroute, Toyo 285 AT II's, FASS 150 HD, ADP Sump, EGR Block, leveled.
CapnDean is offline   Reply With Quote
Old 12-25-2012, 11:11 AM   eBay Motors  #6 (permalink)
bigjohn's Avatar
Sorry about your truck everyone ok.
2006 2500 HD SLT ECLB, LBZ, Bilstein shocks,Banks 4inch exhaust, Alligator Adp Cat filter. And S&B air intake good to be driving a diesel again.
2002 Chevy silverado 2500 HD, LB7, traded it on a gasser and then traded it in for LBZ.
bigjohn is offline   Reply With Quote
Old 12-25-2012, 12:01 PM   eBay Motors  #7 (permalink)
cherokeechief's Avatar
from the looks of it, i know a place near me that can straighten frames better than when it was new. and the pics don't show any severe damage to the frame. the shop is is in alpha, ill and has been doing frame repairs for many years before auto dealers were able to do it.
you can pm me and i will give you the name of the place. the person that does the frame repair was taught by bear alignment. he is the best.
but i would say, the frame may be ok. only way to tell is to get an estimate.
2006 gmc 3500 xcab lb, with the LBZ.
with air dog lift pump, race valve, egr delete, and efi reprogram, thanks to husker diesel.
84 gal fuel cap.34 main and a 50 gal aux transflo system.
20k curt 5th wheel, 20k goose neck.
still stock. 4x4. 430,000 miles and counting.
transporting new units from factory to ia. dealers and ship.
engine replaced at 404,000 mi with one with 118,000 miles.
cherokeechief is offline   Reply With Quote
Old 12-25-2012, 12:01 PM   eBay Motors  #8 (permalink)
Offical LB7 "Tech"
01 D_Max's Avatar
I just had a very serious accident too. My truck is being repaired as we speak. Yours won't be totaled. The frame would have to be pretty f'd up, and it doesnt look like the damage went that far. But if it is you can buy it back for cheap.
-Aaron-
2001 GMC Sierra 2500HD, Limited Edition, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, BATMO, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler- Wastegate, FASS 150, LBZ FPR, Shimmed FPRV, Built Trans, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires,
MANY More extras inside...
01 D_Max is offline   Reply With Quote
Old 12-25-2012, 12:13 PM   eBay Motors  #9 (permalink)
Creepy
TheStepChild's Avatar
wonder if it was The Hitch Hater?
Glad you're ok.
'07 LBZ
'12 Express Van
TheStepChild is offline   Reply With Quote
Old 12-25-2012, 02:50 PM   eBay Motors  #10 (permalink)
zeke38's Avatar
Yes I was ok. The guy behind me didnt even brake I dont think lol. It was in a 45mph speedzone too
