| 06-07.5 LBZ & LLY Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |
| Junior Member Join Date: Oct 2009 Location: Catawba, NC
| Trans Swap Long story short customer wants to swap trans out for a junk yard trans because his is bad. Any pointers or anything i should know about putting trans in like priming or anything like that? new suction filter? fill torque convertor? thanks in advance
__________________ 2001 Chevy 2500hd ext cab.. EFILIVE tunes from the "Supa Tuner" Kory Willis, PPE boost, pyro, fuel rail, 5 Inch junkeye exhaust, XD Hoss 325/60/18 Nitto Terra. 1995 Dodge reg cab 12v Cummins.. 5 Speed Swap, Pump timed and Tuned 2001 VW TDI, EGR delete, South Bend Stage 2 Clutch, Kerma tuning RIP>>>2004 Chevy 2500HD. Strait piped, 18 Inch XD Hoss with 275/70/18 BFG AT's 5 inch turbo back with a 5 to 6 inch tip. Some gauges, EFI live |
| Bump. need a little incite fellas
| Spoolin' Up ![]() | I would deff get a new suction filter and fill the torque converter... I wouldnt ever get a junk yard auto unless I was able to see it working first but its not my choice. Just go the safe route and change filters
__________________ 2006 Chevy 2500HD Duramax Allison ECLB Mods: Cognito 4"-6" with hd sway bar, ballistic jester camo 17x9 rims with 315/70 R17 Treadwright Guard Dog M/T's, Fabtech tie rods, Pitman and dler arm support kit, pump rub kit, 5000k 55w HIDs in high, lows, 4300k 55w in fogs, all on mod, PPE Air box mod, blocked and stuck, PCV re-route and resonator kit, 5" Diamond Eye Turbo back with 7" tip, raptor liner from body line down and holding up perfect! |
| well i said the same thing but when thats what they want what can ya do.... how much fluid will be needed for this?... i have only installed these transmissions from fresh rebuild like a suncoast or something never a used one... what about priming the pump should i pour a couple qts and then crank it and let the trans pump the fluid
| Spoolin' Up ![]() | Well since it is used it will already have fluid in it. I have always just changed the filter and made sure the converter is full then filled it after installed until close and start the vehicle. shift through the gears and add more, repeat till full. You will need a little more fluid then a normal sump filter change.
| Thanks for all the help guys...
| Spoolin' Up ![]() | any time
