| 06-07.5 LBZ & LLY Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |
| Poor acceleration I have a 2007 GMC Sierra Classic with a 6.6 Duramax and a 6 spd Allison trans. The engine light comes on after driving for 5 to 30 minutes and I lose acceleration power. The engine will only tach up to 1800-2000 RPMs even in neutral. The manual shift selector displays all 6 gears but I cannot downshift with the control buttons. I can get up to speed if on a flat or downhill grade but not on inclines. It hasn't left me sitting but I am worried that it may soon. I replaced the spin off trans filter after receiving that suggestion from an online forum. It didn't make a difference. Any idea what the problem is? |
| Senior Member Join Date: Dec 2012 Location: Fort Worth, Texas
| We need the codes.....If you have a P0700 in the ECM, Check for codes in the TCM.
__________________ 2006 Chevy LT3 CCSB 2500HD LBZ/Allison AirDog 100, Nicktane CAT filter head, Billet bleed screw, Blocked EGR, Bilstein, AAM alum. diff cover, Michelin M/S2. 1985 Chevy C20 Suburban with a '04 5.3L/4L60E K&N intake tube w/ stock box, Built trans, Michelin A/S. |
| Ok. I dont have a code reader but I believe Auto-Zone will check the codes for free. I'll do that tomorrow. Thanks. |
| Senior Member Join Date: Jun 2010 Location: Santa Clarita, CA
| When was the fuel filter changed last. How many miles are on the truck? Is the check engine light on? Sent from my iPhone using AutoGuide.com App
__________________ 2006 Chevy Silverado 2500HD CCSB LBZ 2wd: EFI Live by IdahoRob|Edge CTS Insight|Holley HP150|Nicktane FF adapter|Diamond Eye 3" downpipe and 4" straight pipe|S&B Intake|Transgo Jr.|EGR Blocked|PPE Race Valve|4" CST spindle|35" Dynapro ATM's| |
| The mileage is 205k. The check engine light comes on after driving for 5 to 30 minutes. Thats when the loss of acceleration happens. The fuel filter was changed not long ago. It is currently at 75%. |
| Any mods or all stock engine?
| Its completely stock. |
| DuramaxForum n00b Join Date: Feb 2010
| Your truck is going into limp mode. A number of things can cause this but without knowing what codes are coming up theres not much we can do. Mine did the same thing when I bought my truck 3 years ago, fuel filter, problem solved. Can't really go by the DIC for filter percentage since it could have been reset at anytime
__________________ 2006 Crew Cab LLY LT |
| Thanks. I picked up a fuel filter today in case I got some dirty fuel or the filter is just bad for some strange reason. I bought the truck new and have only had fuel filter concernes when I didn't change it after hitting 0%. I had the codes read today and got a P0087 code for fuel pressure too low. It also indicates something about the fuel rail. I didn't make a note of what the exact wording is. Looks like it may need to be repaired by a worthy diesel mechanic if it is within the fuel rail system. Ugh! |
| Change the filter first, Clear the code. A plugged fuel filter can cause a P0087.
