07 lbz fuel return line leaking - Chevy and GMC Duramax Diesel Forum
Old 01-30-2013, 08:16 PM   eBay Motors  #1 (permalink)
butch32's Avatar
As both fuel lines run down the drivers side frame along with the wiring harness the smaller line is leaking where the lines bend and go up toward the motor. My question is what size is this line and can I just use a couple unions and a piece of brake line to fix or a piece of rubber hose and a couple hose clamps? What would u guys do? Thanks for
Your help, Lawrence
butch32 is offline   Reply With Quote Quick reply to this message
Old 01-30-2013, 08:23 PM   eBay Motors  #2 (permalink)
SST 1953's Avatar
I would cut t and splice in a compression fitting. A rubber line would probably be just fine, as its a return line. It should be 3/8 line
2007 CCSB LBZ.
EFI live DSP 5 by Rob @ ATP
EGR blocked, PVC reroute
AirDog II 165
TransGo Jr/pump rub mod
Firestone bags
4" MBRP
Edge Insite CTS w/ backcam
Cognito W/Bilsteins
69 Camaro S/ST-S/Gas
SST 1953 is offline   Reply With Quote Quick reply to this message
Old 01-30-2013, 10:28 PM   eBay Motors  #3 (permalink)
ieetgluu's Avatar
Mine started leaking a couple moths back. I replaced it, motor to cooler, with 3/8" barricade hose (rubber sae30r14)
Chad
04.5 4x4 ~149k miles
DE 4", 5100s, LBZ MP, S&B LBZ air, KoryWillis Go-go Juice, Insight CTS, ADII, 8' Fisher, Highroller Ultimate Idler Arm, Profab delete, XD RareParts tie rods
Dirtymax this, Dirtymax that...
ieetgluu is online now   Reply With Quote Quick reply to this message
Old 01-31-2013, 03:10 PM   eBay Motors  #4 (permalink)
butch32's Avatar
All fixed. piece of steel line and a couple unions.
