LBZ Rolling Coal! - Chevy and GMC Duramax Diesel Forum
Old 06-06-2013, 05:58 AM   eBay Motors  #1 (permalink)
DRTYMAX13's Avatar
LBZ Rolling Coal!
OK, now that I have your attention... this isn't one of those threads. Yet another problem this morning on the way to work... Merging onto the highway and the truck had very minimal power and I noticed something in my mirror and it was a huge cummins style cloud of black smoke then it cleared then it rolled again, all while throttle position stayed the same. Truck seemed to clear up a bit and I made it 1/2 mile down the road to work.
Question is: where do I begin to look? I won't have access to a scanner until this afternoon and I'm not sure what new CEL I have, if any, because they stay on constantly anyway due to my brake issue, blocked egr, etc.
Truck has no tuning on it right now whatsoever and my AD died last week so I had to put the factory filter head back on to prime it and run and it also would not crank this morning until I primed it back up.
With those symptoms can any one offer some advice as to why this turd is rolling coal now?
2006 GMC 2500HD LBZ "CMNSKLR" - SOLD
DRTYMAX13 is offline   Reply With Quote Quick reply to this message
Old 06-06-2013, 06:10 AM   eBay Motors  #2 (permalink)
k_mccoy_7's Avatar
Did you put a new fuel filter on?
Sent from my SCH-I535 using AutoGuide.Com Free App
-2004 LB7
-20x10 FUEL Hostage wheels
-33 12.50 20 Toyo open country M/T
-4 inch exhaust 6 inch tip
-BCI intake w/ S&B filter and turbo horn
-5% tint
-Efi Live w/ dsp 5 from ATP
k_mccoy_7 is offline   Reply With Quote Quick reply to this message
Old 06-06-2013, 06:12 AM   eBay Motors  #3 (permalink)
DRTYMAX13's Avatar
Yes, the factory filter is brand new and the AD filters are less than a month old... did them right before the pump decided to quit me
Old 06-06-2013, 06:24 AM   eBay Motors  #4 (permalink)
blue8135's Avatar
Any codes? Try cleaning MAF
2006 Chevy 2500 HD 4x4, LBZ, Ranch Hand Front Bumper, B&W Gooseneck Hitch, SDP EGR Delete, PCV rerouted, EFI Live w/V2, 4094 AVNT, Edge Evolution (Gauges only), Mike L. Stage 4, M.L. Converter, Merchant Auto Pump Rub Fix, Transbrace, Air Dog II 165, LML Ex. Manifold, PPE Airbox Mod, and more to come...
blue8135 is offline   Reply With Quote Quick reply to this message
Old 06-06-2013, 06:37 AM   eBay Motors  #5 (permalink)
DRTYMAX13's Avatar
cleaned the maf about a month ago as well... not sure on any new codes until lunch at the earliest... CEL stays on for other reason so I'm not sure if anything new has come up. With no tuning I'm just trying to figure out if this is an air or fuel issue (i.e. - boost leak or injector) I guess I really won't know until I hook the scanner to it. Figured somebody would have had to run in to something like this at some point
Old 06-06-2013, 06:43 AM   eBay Motors  #6 (permalink)
blue8135's Avatar
Ok. Post back with the codes. Help narrow it down some. But still could possible be the maf. (Cleaning or replacement). Egr could cause same issues but I see it's blocked?
Old 06-06-2013, 06:51 AM   eBay Motors  #7 (permalink)
DRTYMAX13's Avatar
egr is blocked
Old 06-17-2013, 06:25 PM   eBay Motors  #8 (permalink)
robphillips00's Avatar
Turbo solenoid. Not sensor. My 05 did almost exactly what you are describing. No code either. That dang part is pretty high.
06 GMC 3500 CCLB DRW SLT 4x4-EFI LIVE, Nicktane filter adapter, fass 150, new head gaskets and Lmm heads, replaced injectors, airbags, yada, yada
06 CC Duramax 3500 DRW Custom Flatbed-sold
08 GMC CCSB SLT 4x4 White on Black Leather, Moto 951's, Leveling kit with airbags, Ranchhands on front and rear. RollBak bedcover, EFI LIVE by Rob, EDGE CS and MBRP exhaust.
robphillips00 is offline   Reply With Quote Quick reply to this message
Old 06-30-2013, 05:45 PM   eBay Motors  #9 (permalink)
BAMAWHISTLER's Avatar
if the turbo solenoid starts going bad, will the turbo whistle sound change totally sometimes at idle during parking?
2006 2500HD LT2 CC SB 2WD LBZ Allison 3.73
EFI LIVE, DSP5, PPE airbox mod, Edge CTS, PPE manifolds/uppipes, MBRP DP, MBRP 4" Turbo back stack kit, black cloud 6" x 4' bullhaulers, resonator delete, sinister egr delete, pcv reroute, lift pump & filter/water separator, coolant bypass filtration, westin steps, AMI big stick, some tint, a little chrome
1996 Honda 300 Fourtrax, 24" & 25" ITP Mudlites
2013 Polaris 550 Stealth LE, 28" ITP Mega Meyhems & a set of 26" Bighorn 2.0s
2000 Harley Davidson 1200 Custom, Smoked lenses, dentist mirror mod
BAMAWHISTLER is offline   Reply With Quote Quick reply to this message
