| Welcome to the forum. Sounds like you have an SL model which I do believe will not have the DIC.
Transgo Jr. is a decent mod to the 6 sp allison and will handle up to 500 RWHP..any more power than that, suggest a built tranny.
If longetivity is of concern, you wish to look at these items:
Secondary oil Filtration - FS2500 or Amsoil - both are very good bypass filter set-ups and will lengthen your oil change intervals BIG time..especially nice if you are using synthetics.
Secondary fuel filtration - Nicatne or similar set up using a large CAT filter. If you do this mod, a lift pump might not be a bad idea - as pulling fuel through 2 filters before the cp3 can put extra strain on said injector pump.
Be carefull on air filters and suggest you research lots before changing from the OEM paper one (still the best filter out there IMOP), to a cleanable.
To my knowledge, your LLY is exactly the same as an LBZ - just de-tuned to 310 hp and I think that the airbox may be a smaller OD..not too sure on that one though.
__________________ 06 LBZ CCSB SLE Blanco Tricked just a bit - All MOds in the Garage 152,365 miles Preferred Diesel Performance Shop..?? Oakville, Ontario CANADA..eh
