Old 08-30-2007, 05:43 PM   eBay Motors   #11 (permalink)
KB3MMX
KB3MMX's Avatar
Originally Posted by John-Boy 331 View Post
what about mobile del vac? good bad
Delvac 1300 is good ...for a Dino oil,
The "DELVAC_1" is the synthetic version, also the same is the 5W-40 "turbo diesel" oil they offer(Mobil).
Both are fantastic oils.
---Chuck
Ham Radio= Global communications without airtime fees
(my antenna)
http://www.steppir.com
07' Chevy Silverado HD --CC, SB Duramax Diesel/ 6 spd Allison Auto
--Silverline Stainless Exhaust
--K&N drop in replacement air filter
--17MPG City, 21MPG Highway
--XenonDepot Xtreme HID's (6000K)
KB3MMX is offline   Reply With Quote
Old 08-30-2007, 10:18 PM   eBay Motors   #12 (permalink)
DuramaxChad
Royal Purple
Ya'll might ought to look in to Royal Purple as a Syn option....Where I am from in Waco, Texas it's pretty easy to get a hold of. I have run it for years in everything from a 9 second 1/4 mile car I once owned to a center console fishing boat we now own. I don't know if I am just being bias toward Royal Purple, but I have never and I mean never had any catastrophic engine failures when I was running this stuff......Failure meaning any internal component. Hell I run the stuff in my lawnmower too. I love it!!
DuramaxChad is offline   Reply With Quote
Old 08-30-2007, 10:43 PM   eBay Motors   #13 (permalink)
Diesel Nut
Diesel Performance
Diesel Nut's Avatar
You're not being biased, just happy with your results. Nothing wrong there! Royal Purple is a good oil, but cost wise Amsoil is still a better choice, unless you have a hook up. Out here on the west coast Royal Purple is harder to come by, but Red Line is abundant (its made out here). Red Line is decent too.
As for the other brands (Mobil, Shell, Cheveron, ect), just do your research on the products. You might be surprised what you find.
We are very busy in the shop, please call for fastest service!
Diesel Nut Motorsports
Everything you need for perfomance
Suncoast, PPE, EFI live, you name it, we have it
1-800-450-7036
Amsoil Online Store
Save some money - Become an Amsoil Preferred Customer
Make some money - Become an Amsoil Dealer
Diesel Nut is offline   Reply With Quote
Old 09-21-2007, 05:43 PM   eBay Motors   #14 (permalink)
acarrpenter
acarrpenter's Avatar
I am a little nervous to switch to the syn, three trucks ago i bought into the hype. Immediately after switching from valvoline conv. to "syntec" i started useing oil it just dissapeared, not out the tailpipe not into coolant just dissapeared into oblivion. switched back after two or three oil changes with syn and problem gone never used another drop
06 chevy lly crew cab 4x4 s/b
3" keys up front 1" block in rear
20x10 Moto Metal 955
305 terra grapplers
4" silverline turbo back exhuast
Edge juice with attitude hot unlocked
intake modified
resonator blocked
access literider roll up tonneau cover
acarrpenter is offline   Reply With Quote
Old 09-21-2007, 06:07 PM   eBay Motors   #15 (permalink)
KB3MMX
KB3MMX's Avatar
Don't sweat it.
However..., if you want a true synthetic, "Syntec" made by Castrol is not the one for you, it is simply a highly refined hydrocracked Group 3 oil.
Mobil, Royal Purple and Amsoil are all true synthetic "PAO" oils.
---Chuck
(my antenna)
Old 09-27-2007, 03:42 AM   eBay Motors   #16 (permalink)
Diesel Nut
Diesel Performance
Diesel Nut's Avatar
From my experiences, when switching over to Amsoil, typically a motor will appear to use about a quart in the first 5k miles. Top it off and it will not use any more. My understanding here is that the oil dino oil that is trapped in the block and mixes with the syn slowly boils off. A quality Syn will not boil off NEARLY as fast as dino oil This would explain why after the first quart, it doesn't use oil again. usually there is about 1-2 quarts of oil trapped in the block during a change, depending on the motor.
1-800-450-7036
Amsoil Online Store
Old 09-28-2007, 06:36 AM   eBay Motors   #17 (permalink)
KB3MMX
KB3MMX's Avatar
This is true, a conventional has MUCH higher Volatility(boil off) than synthetic PAO oils.
I'll also add that after the changeover, there is varnish and grime being cleaned up by the synthetic oil that the conventional left behind. One area that can get very noticeable cleaned s the ring lands. This can be seen from an engine that consumed oil and was changed over to synthetic, then several thousand miles later, the oil consumption has tapered off to nothing or is greatly reduced. This has been experienced by me on several high mileage vehicles that have been converted to synthetic oils over the years.
---Chuck
(my antenna)
Old 09-28-2007, 07:29 AM   eBay Motors   #18 (permalink)
pete37922
the rotella 5w-40 iz hydrocracked oil also...thats why i switched 2 Amsoil 4 my Powerstroke engine !!!
pete37922 is offline   Reply With Quote
Old 09-28-2007, 08:07 AM   eBay Motors   #19 (permalink)
KB3MMX
KB3MMX's Avatar
Yep, Rotella and Castrol are the fake's in the "synthetic" market.
Amsoil, Mobil1 and Royal Purple are true "PAO" group 4 synthetic oils.
---Chuck
(my antenna)
Old 09-28-2007, 09:26 PM   eBay Motors   #20 (permalink)
pete37922
Amsoil 2 me iz the best !!!
