Chevy and GMC Duramax Diesel Forum (http://www.duramaxforum.com/forum/)
-   06-07.5 LBZ & LLY Duramax Powertrain (http://www.duramaxforum.com/forum/06-07-5-lbz-lly-duramax-powertrain/)
-   -   Oil capacity and type questions... (http://www.duramaxforum.com/forum/06-07-5-lbz-lly-duramax-powertrain/23784-oil-capacity-type-questions.html)
Reidler 05-08-2009 09:48 AM
OK, SO I am going to convert my truck over to Amsoil this week, but need some info.
First of all, capacities:
-Allison 6 speed trans with stock pan (enough for a complete flush and filter change)
-Duramax engine oil (including filter)
-stock rear end
-Transfer case
Next, types:
-Transmission. ATL or Torque-Drive (ATD)
-Engine. I think I have my mind made up on this one already. Going with the HDD 5W-30
-Differential. no idea which one to use.
-Transfer case
Finally, filters:
-Engine oil filter: I want to go with the Ea filter but don't know which one.
My stock air filter is still fine and I will probably stick with it.
Thanks for any and all help!
j4nash 05-08-2009 09:53 AM
bigdaddydiesel is the man to ask. He can help you out with what is best to run.
bigjerm7 05-08-2009 09:56 AM
+1 for the stock rear end capacity. 3.73 is all i can find and the amsoil site has the ring gears listed. 09 3500 4wd 6.6l.
Toypuller 05-08-2009 10:09 AM
BAD idea on the engine oil. You need more viscosity.
mrmanners 05-08-2009 10:18 AM
Bigdaddydiesel can provide you a list of types of fluid and capacities from the AMSOIL website. Great stuff, you won't be sorry.
Reidler 05-08-2009 10:20 AM
Ok, what's your suggestion?
That's why I posted. I want to get the right oil the first time. The Amsoil literature say use HDD.
palposity 05-08-2009 10:22 AM
x3 on bigdaddydiesel he knows all.
bigjerm7 05-08-2009 10:23 AM
5w-40 ain't a whole lot different from 10w-40.
bigdaddydiesel 05-08-2009 11:16 AM
Ok...
You Pay What I Pay Always!!!
First of all, capacities: I am going to send you a link to help you find all of the proper capacities for ANY application, not only your truck.
Ordering Three Gallons Of Torque Drive will do the full flush for the tranny and transfer case
You need 2.5 Gallons Of Oil I highly recommend the 5w-40 Premium DEO, it is the best overall diesel oil we offer, period.
-stock rear end
4 pints of Severe Gear 75w-90 in both the front and rear diffs for light duty applications.
-Transfer case
Refer to above
Next, types:
Yep, that is the one.
Nope, I highly recommend the DEO Premium 5w-40
Severe Gear 75w-90
-Transfer case
Torque Drive
Finally, filters:
Part # EAO52
The EA Air Filters are Heads and above better then stock and they are direct replacement, cleanable dry filters that offer sub micron particle filtration over and above any other filter on the market period. Let me know if you would like more info on that.
You are MORE than welcome.
I hope this helps, but let me know if you would also like to know how to save up to 25% off of retail prices with your order!!!
God Bless
Chris
bigdaddydiesel 05-08-2009 11:22 AM
For anyone wanting to check capacities, click the link below and then enter your truck information and then once the recommended product page is up go ahead and scroll to the bottom of the page to the capacities section.
AMSOIL Auto and Light Truck Online Look up Guide
