| 06-07.5 LBZ & LLY Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |
| Junior Member Join Date: May 2009
| Removing rear brake rotors from dually Is there something special about removing the rear rotors from an 06 GMC dually? I need mine turned and most local brake shops say they can't do it.
__________________ Ride 2006 3500hd LLY GMC! UpGrades 4'' MBRP turbo back, Quadzilla stealth2 (90hp) |
| bumpin it up
| Junior Member Join Date: Apr 2009
| You have to pull the rear hub off, and remove the rotor from the hub. Its not simple as just pulling the rotor off but its not that hard. 1. remove wheel 2. remove axle retaining bolts and slide axle out 3. remove brake caliper and bracket 4. remove hub retaining nut 5. slide rear hub off of axle housing 6. lay hub and rotor assy. with studs pointing upward 7. take a brass drift/block(so you don't damage the stud) and hammer(I used a air hammer) and drive the wheels studs backward out of the hub 8. then just remove the rotor from the hub Once you get them off you can take them to most parts stores and they can turn them for you dirt cheap. BTW they can do it, chances are they are just too damn lazy
__________________ 06 Chevy 3500 Crew Cab DRW 6.6l LBZ 6spd Allison 4x4, Some brand of 5" exhaust and :rockin Edge Evo Race :rockin |
| LHN...We ARE the Joneses ![]() Join Date: May 2008 Location: Awww-stin, TX
| I didn’t have the time to do mine (DRW) years back, and every so-called Brake Specialist I contacted left me less than confident in their abilities. In fact, their typical response reminded me of that Transmission Commercial from years ago with the line, “I always wanted to work on a trans-mish-eon!” Ever done brakes on a DRW? “Nope. But bring it on in, we’uns can fix ‘er up fer ya.” I had to get back on the road, so I let the Dealer do it. They turned the rotors with ‘em on the truck, not removed. Not cheap, but time was money back when the economy was hot. Which seems like ancient times now...so long ago. :tease
__________________ 2007 LBZ 3500 LT3 DRW Crew Cab, Sulastics, Putnam XDR 15K, B&W 30K-Turnover GN+Companion, Ride-Rite Air...EFI'd by Rob 2008 LMM 3500WT DRW Crew Cab, 8 'Flat/GN, Workforce Alum Toolbox, Ride-Rite Air, SulasticsUse-ta Haves 2006-6.0 3500 WT DRW ExCab Flatbed, 2005-LLY 3500 LS DRW Crew Cab, 2002-LB7 3500 LS DRW Crew Cab I Live my life in such a way that when my feet hit the floor in the morning...Satan shudders & says "Oh shit, he's awake!" |
| What rotors and pads do you recomend? |
