Old 06-27-2009, 10:48 AM   eBay Motors   #1 (permalink)
devo
slight play in front left tire?
well since i bought the truck a couple weeks ago,ive been hearing a really slight noise like something is loose in the tire when i hit a bump or turn left on like a dirt road,like there is play in either the wheel or the steering wheel,could it be a wheel bearing or something coming on slowly?
06 Dmax LLY w/6 spd ally
MBRP 4 inch TB exhaust(straight pipe)5 inch tip
Blocked Res.
Quad stealth 2
murdered tint
PPE airbox mod
Rough country tierod sleeves
EGR blocked//PCV re-route
Terra Grapplers(285's)
Readylift Level kit
14.51@93mph 2wd.soo far
devo is offline   Reply With Quote
Old 06-27-2009, 11:46 AM   eBay Motors   #2 (permalink)
jc1843
Most likely it is the ISS (shaft that runs from the lower column to the steering gear) Common problem. This in not a safety problem, just annoying. requires a new shaft- about $100 and a half hour labor. (Be sure to tie the steering wheel down if you do it yourself.)
It is also a good idea to jack up the truck and check for play at the 12 to 6 O:clock position, and at the 9 to 3 O:clock positions. This will tell you if you have wheel bearing or loose steering.
Chevy 04.5 LLY, 265s, shell, XDR, MikeL 6spd, TransGo, deep pan, blocked, fingered, de-badged, PVC, 65 Gallon Aero tank, PPE, LBZ- mod, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags
Old 07-02-2009, 09:06 AM   eBay Motors   #3 (permalink)
Weasel Diesel
JC hit it on the head. ISS. When mine went bad, I went looking for bad ball joints or tie rod. Thats what it sounds like.
2006 2500HD 6.6 LBZ
6 Spd. Allison
All Stock exc. coolant filter kit.
Weasel Diesel is offline   Reply With Quote
Old 07-02-2009, 09:09 AM   eBay Motors   #4 (permalink)
daddysLBZ
ONEFASTCOONASS..
daddysLBZ's Avatar
Beware the hubs!!
I just changed my driver side hub assembly 2 weeks ago...The GM part is 459,and if you get the dealer to do it it is about 600-700 bucks..Jack up the truck,rock the wheel using your hands at the 12 and 6 o clock positions..If it has play you know that is it!!
06.LBZ GMC[SLE1] 4x4 ....114k miles,4136 hours[Modded a bit.LOL]
1987 Monte Carlo SS 89k
1978 Malibu
FORMER DURAMAX FORUM MODERATOR...........i HAVE YOUR iNTERNET pROVIDER ADDRESS...:tease
Old 07-02-2009, 10:06 AM   eBay Motors   #5 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
Yeah if it is only doing it when you are turning one way, i would say wheel hub. Dmaxstore.com (vendor here) sells the hub with the timken bearing in it for around 200. It does pay to shop around. I called napa and they wanted 450...callled schucks (o'reilly) and it was less than half the price for the EXACT same part number which is the same one that Dmaxstore.com sells.
the hub is easy to check and change yourself. Just jack up the front and see if your tire moves when you try to rock it at 12 & 6 o'clock. If there is movement...get a new hub.
Old 07-02-2009, 10:16 AM   eBay Motors   #6 (permalink)
RedBowTies88
RedBowTies88's Avatar
also if your tires move around when jacked up it could be your idler/pitman arms...i have this problem on my truck
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Old 07-02-2009, 10:18 AM   eBay Motors   #7 (permalink)
K9Duramax
K9Duramax's Avatar
You can also grab the steering shaft outside the firewall and try to move it up and down to see if you get any play out of it. There should be no movement in it, if there is then your shaft is bad.... as stated above, no safety issue but annoying as heck!!
'05 CC/SB, AMSOIL 5w-40, KN Cold Air Intake, PPE Tuner level 1, EGR blocked, MP mod, res. plugged, lost KITTY, finished off the rest with 4" SS Magnaflow
Synthetic Motorsports
http://lb7.info/
K9Duramax is offline   Reply With Quote
