06-07.5 LBZ & LLY Duramax PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
Only Getting 12.7 MPG any ideas guys
2006 2500hd
Volant cold air intake
4inch exhaust no cat
Bullydog outlook
New fuel filter
New oil
only getting about 260 miles a tank.
__________________ John C
2006 2500hd
Volant intake
Transgo Jr
4 inch turbo back exhaust.Royale purple in diffs
Bullydog outlook with shift on the fly
Heavy right foot installed at birth
snugtop canopy with remote open.30ft trailer weighs about 8k pulling it at 70mph getting 11 mpg
i agree with Brian. but also what are you running that bullydog on?
maybe if you foot is quite heavy (as is mine) you would actually benefit from keeping that on a really low setting unless your doing highway cruising.
i found doing that worked the best when i only had my banks
also check out your air filter unless its one of those new fancy ones it may need a good cleaning
Cc/sb LLY 4x4, aerodynamic passenger door dent mod, 6-gun/SL and SC flashpaq, egr blocked, factory 3 1/2 straight piped, banks ram air, home made spring clamps, sleeves and braces, msd dual lazer gauge. Trutrac Diff. NEW BEST TIME... 14.140 at 94.69 still using 2WD
maybe check tire pressures, air filter for cleanliness, you have a new fuel filter, has this been going on for a while, maybe bad batch of fuel in the tank
__________________ Derek Wessels 2005 Chevrolet 2500HD crewcab LLY, LT3 package
Banks 4" Monster Exhaust, S&B cold air intake, and Kodiak mouthpiece
B&W turnover fifthwheel, Pac-brake air springs
BF Goodrich All-Terrains 285/75/R16 on stock rims
Mods to come: mbrp cat delete pipe, congnito tie rods, and PPE Excellerater Standard
Air filter is clean /Tires full. And I was driving it to see what it would get for MPG no hot footing. I know it should be getting atleast 16mpg
2006 2500hd
Volant intake
Transgo Jr
Is your mileage hand calculated, or are you using the computer estimate?
__________________ 2005 HD2500 Silverado 60K miles
LBZ mouthpiece upgrade
TCAI from Killer Bee Custom Tune (ECM) awaiting extra cash
New Exhaust minus Cat (4") will be installed once I have a new ECM programmed (Tow/Mileage Tune)
2006 2500hd
Volant intake
Transgo Jr
