06-07.5 LBZ & LLY Duramax PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
My 06, 3500 Dually, Crewcab 4X4 came with 215/85-16 tires and I want larger, stronger tires. I'm told I can go to 265/75-16 tires but will need to add a 2" spacer between the real duals.
Has anyone done this?
Will the rear tires stick out past the rear fenders?
NEED ADVICE. Thanks!
if you want a tire that is as tall as a 265 but not as wide go with the 235-85R16(thats what i run on our dually's)but if you want a taller you can run 285-75R16 but like you said you need spacers to run them but the thing i don't like about spacers is it adds extra stress to the studs and lugnuts IMO so i would highly recommend staying with the 235's..before i forget welcome to the forum
__________________ James
TyreBoyz Pulling Team
most tires are in metric sizes anymore..
heres some converted sizes for your convience..
215-85R16=30-7.50R16
235-85R16=31-8.00R16
255-85R16=33-9.50R16
265-75R16=31-10.50R16
285-75R16=33-11.50R16
295-75R16=34-11.50R16
