engine light help 06 duramax - Chevy and GMC Duramax Diesel Forum
Old 11-30-2007, 09:09 AM   eBay Motors  #1 (permalink)
i have an 06 duramax, 50,000 miles. the usual aftermarket exhaust, programmer, and intake. runs decent, but if i hold it very long, usually when it gets over 100 mph the engine light comes on and i get codes like "engine overbooster" "egr" and something about a thermostat bullydog said it was because of the aftermarket exhaust having no cats and it wasn't a big deal any comments or ideas how to stop it or if i should worry about it
daniel99ta is offline   Reply With Quote Quick reply to this message
Old 11-30-2007, 10:10 AM   eBay Motors  #2 (permalink)
Diesel Addict
when the light comes on do you get a 2K rpm gov?
the way to stop the EGR codes is installing the EGR block plate and the Fingerstick..
Project, Rogue Budget(Workstock Puller)
2006 GMC 2500HD, Stock Motor, EFILive by me, Billet 63 VVT, Motorsport Stroker CP3, 20% Nzls, ProFab Manis n Uppipes, BD IC, Hot Pipe IC, ProFab Y-Bridge, lots of other goodies
TYREBOYZ_DEMAXIN is offline   Reply With Quote Quick reply to this message
Old 11-30-2007, 10:13 AM   eBay Motors  #3 (permalink)
BryanVilaubi's Avatar
Get the codes and I will tell you exactly what they mean. It sounds like it might be going into limp.
2003 GMC Sierra LB7
New motor in the works as we speak with lots of goodies!!!
BryanVilaubi is offline   Reply With Quote Quick reply to this message
Old 12-03-2007, 10:08 AM   eBay Motors  #4 (permalink)
arctic_cat27's Avatar
i have an 07 with 18,000km and its doing the exact same thing. replaced the map sensor a few days ago and worked fine until thismorning. its going to the dealership tomorrow to be looked at. code said turbo overboost or something like that. it goes into limp mode and the only way i can get it out is by unplugging the map sensor, but the CEL still is on. also, when i turn the truck off, i can hear a solenoid or something buzzing for a few seconds
arctic_cat27 is offline   Reply With Quote Quick reply to this message
Old 12-03-2007, 01:27 PM   eBay Motors  #5 (permalink)
Diesel Addict
artic_cat27,pull the CEL codes so we know what your dealing with..also welcome to the forum artic_cat27..
Old 12-05-2007, 07:40 AM   eBay Motors  #6 (permalink)
the exact codes are:
po401 --EGR Flow insuficient
po108 --BARO Circuit High Manifold Absolute Pressure
po128 --Coolant Thermostat Malfunction
po234 --Engine Overboost
I got the names of each code off of bullydog dtc's list
Old 12-05-2007, 08:10 AM   eBay Motors  #7 (permalink)
The LBZs are very picky motors. I see these codes thrown all the time in the LBZ motors. Chances are, it has to do with your tuner (Crazy Larry is known to do this) so EFI Live may be something you might want to look into if you get tired of throwing these codes. You can completely eliminate these codes because the motor will not even run a diagnostic on startup. Your best bet right now is to clear the codes and start over. If it throws them again, tell us what you were doing when it happened. ex: boost pressure, throttle position, EGTs roughly..........just as detailed as you can.
2003 GMC Sierra LB7
Old 12-05-2007, 05:45 PM   eBay Motors  #8 (permalink)
IdahoRob's Avatar
Blocker plate maybe?
Most likely from after market filter, try cleaning MAP sensor. EFI can rescale the MAP tables to fix this if desired
Got me there
Most likely from the tuner, EFI also can change parameters to fix
As stated from Bryan, the codes can be turned off or parameters can be changed with EFI to fix your problems. The overboost code is the code that is limping the truck.
Take care,
Rob
2007 LBZ tow rig/Daily driver, stock engine 11.70 @ 115mph on #2, 677 HP, MPI Twins
2002 LB7 Max'd Out 9.71@141+MPH on #2 fuel only, MPI Twins
EFI Live, Suncoast Dealer, Dmax Hotrod Parts
Adrenaline Truck Performance 208.484.3670
IdahoRob is offline   Reply With Quote Quick reply to this message
Old 12-10-2007, 09:54 AM   eBay Motors  #9 (permalink)
it wasn't the crazy larry setting, it was the 130-150 setting or whatever it is. unfortunatly i don't have any gauges so the only thing i can tell you is the throttle position...wfo! It usually throws them when i hit over 100 mph
Old 01-25-2008, 04:45 PM   eBay Motors  #10 (permalink)
scotts's Avatar
Try only going 99 mph I could not resist.
06 cc sb lly straight piped stock exhaust, fingers stick,egr blocker and a diablosport predator
66 chevy 502bbc with powerglide and a bunch of go fast parts best et 9.38 @144 mph
scotts is offline   Reply With Quote Quick reply to this message
