Old 10-17-2009, 03:27 PM   eBay Motors   #11 (permalink)
K9Duramax
K9Duramax's Avatar
have you tried to use a mechanic stethoscope (dirt cheap at Oreilly's) or a broom handle/long screw driver to get a little closer? If it is ratting that loud, you should be able to get pretty close to it using one of these methods....
'05 CC/SB, AMSOIL 5w-40, KN Cold Air Intake, PPE Tuner level 1, EGR blocked, MP mod, res. plugged, lost KITTY, finished off the rest with 4" SS Magnaflow
Synthetic Motorsports
http://lb7.info/
K9Duramax is offline   Reply With Quote
Old 10-17-2009, 03:31 PM   eBay Motors   #12 (permalink)
kansas
kansas's Avatar
The ratteling could be a broken flywheel, Im not sure on the surging part.
Stock 05 LLY A/T 4x4 CC SB
01 Cummins Dually Quad cab 2WD Straight piped Powermax and built trans and converter.
kansas is offline   Reply With Quote
Old 10-17-2009, 03:43 PM   eBay Motors   #13 (permalink)
Odyssey25013
thanks for all the suggestions. i think i may take it to the stealership. they have been good to me lately.
2006 LLY LT3 EC/LB
Resonator Blocked
Air Box Modified
Whelen LINZ6's in the grill
Magnaflow Stainless 4" TurboBack
Odyssey25013 is offline   Reply With Quote
Old 11-04-2009, 11:43 AM   eBay Motors   #14 (permalink)
robert987
check the r harmonic balancer if the rubber is bad on the balancer it will rattle bad when idiling and when you let off the thorottle and will vibrate thru the crank making it sound like the torque converter
robert987 is offline   Reply With Quote
Old 11-04-2009, 01:06 PM   eBay Motors   #15 (permalink)
Odyssey25013
Thanks. the stealership couldn't find out what was wrong so Im up for anything now.
2006 LLY LT3 EC/LB
Resonator Blocked
Air Box Modified
Old 11-04-2009, 01:09 PM   eBay Motors   #16 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
my only experience with rattles to this nature was either a spun bearing or the flex plate was shreaded! none of it is cheap!
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 11-04-2009, 01:42 PM   eBay Motors   #17 (permalink)
Odyssey25013
Great more money to spend that I don't have. But if it needs to be fixed, it needs to be fixed
2006 LLY LT3 EC/LB
Resonator Blocked
Air Box Modified
Old 11-04-2009, 03:16 PM   eBay Motors   #18 (permalink)
Kst8er
i had a similar rattle on mine (glad to see someone with more miles than me on an 06 LLY, 95k here)
funny thing is it would go away when I would go thru a car wash... i found that i had 2 things, first was a heat shield near the down pipe that i think was too close to the exhaust... i bent it slightly back away from exhaust... second, i still have my cat & from hitting the exhaust with my hand, it sounds like something is loose rattling in the cat... haven't had the noise for a couple of weeks (& i haven't washed it in a couple of weeks)
my $0.02
Rattlin & Gobblin
2006 Chevy 4x4, CCSB, LLY, Hankook RF10 265s, MIA muffler
Kst8er is offline   Reply With Quote
Old 11-04-2009, 05:32 PM   eBay Motors   #19 (permalink)
Odyssey25013
sounds like i need to do some cleaning
2006 LLY LT3 EC/LB
Resonator Blocked
Air Box Modified
Old 11-07-2009, 08:34 PM   eBay Motors   #20 (permalink)
Odyssey25013
So far nothing has worked. Still a mystery to what the rattle is, but there is a new symptom...yippee. I stop the truck and put it into park, as I let off the brakes it rattles then stops. Its starting tick me off, dealer can't find anything either.
2006 LLY LT3 EC/LB
Resonator Blocked
Air Box Modified
