Old 11-02-2009, 04:00 PM   eBay Motors   #1 (permalink)
John-Boy 331
John-Boy 331's Avatar
abs
ok i get in my truck in the morning and by the second stop you can feel the brake pedal being lessoned by the abs and feel it in the right front, after that its fine? also the abs light will come on sometimes while turning slow after starting?
06 LBZ 3500 4x4 single rear wheel regular cab long bed WT, 4" turbo back straight pipe, solid gooseneck, drw wrecker prep springs, blocked, fingured, 2"plugged, and plenty of UWS boxs. work in progress
John-Boy 331 is offline   Reply With Quote
Old 11-02-2009, 04:43 PM   eBay Motors   #2 (permalink)
Ridin'GMC
Ridin'GMC's Avatar
The wheel speed sensor for the ABS in the hub is dirty. Take the tire, brake rotors off and take out the wheel speed sensor that is on the hub, sand it down lightly so the rust is off and put it back together. If it continues, replace the sensor. Make sure there are no mud on the cv driveshaft reluctor wheel.
06 LLY CCSB
Just another white truck on the site.
Tuned by Killerbee's Original LBZ tune.
480 rwhp & 830 lb-ft of torque as of 11-7-09 on stock tranny
Ridin'GMC is offline   Reply With Quote
Old 11-05-2009, 07:26 PM   eBay Motors   #3 (permalink)
John-Boy 331
my sensor is brass and a small layer of grease? any other ideas thanks
