Old 11-05-2009, 06:47 PM   eBay Motors   #11 (permalink)
D-MAX Mafia
Wide Open!!!
D-MAX Mafia's Avatar
One o-ring is on top of the filter the other goes on the bottom. i like to fill it with tranny fluid before i put it back on. Clean the pipes!!!
06 CC/SB LBZ
I got a D-MAX Baby!
Tuned with EFILive
D-MAX Mafia is offline   Reply With Quote
Old 11-05-2009, 06:55 PM   eBay Motors   #12 (permalink)
bigdawg1
i tried disconnecting both cables and looks like it won't reset , so i will have to get a filter in the morning and see what that does .....
is there other things it could be or is this a common problem when filters get plugged??
i was just worried it was something more major
thanks
for any and all input
bigdawg1 is offline   Reply With Quote
Old 11-05-2009, 06:58 PM   eBay Motors   #13 (permalink)
D-MAX Mafia
Wide Open!!!
Its common if the filter hasn't been changed in a while or you got some bad fuel. But its always the first thing to check.
06 CC/SB LBZ
I got a D-MAX Baby!
Tuned with EFILive
Old 11-05-2009, 06:59 PM   eBay Motors   #14 (permalink)
Johnasara
Yeah, That guy!!!!!
Johnasara's Avatar
With the symptoms you have described it is most likely the fuel filter. The Duramax is not happy unless it gets plenty of fuel. It will also help if you clean the MAF sensor. You have a K&N filter and they are known to throw oil all over the MAF sensor. I have one on my LMM but I carry around a can of spray for when it happens.
4" DIAMOND EYE EXHAUST,
DIABLO @ 120,S&B COLD AIR INTAKE, RESONATOR PLUGGED
AUTOMETER ULTRALITE GAUGES, TRANSGO JR, EGR BLOCKED!!!!285/75 BFGs ON ULTRA DYMONDS, TIE ROD SLEEVES....Its Coming.....EFI LIVE.....
WORK RIG
Johnasara is online now   Reply With Quote
Old 11-05-2009, 07:01 PM   eBay Motors   #15 (permalink)
bigdawg1
how often should i change filter and what should i use to clean maf sensor
Old 11-05-2009, 07:03 PM   eBay Motors   #16 (permalink)
D-MAX Mafia
Wide Open!!!
I change mine with every oil change. Which is every 5000 miles.
06 CC/SB LBZ
I got a D-MAX Baby!
Tuned with EFILive
Old 11-05-2009, 07:12 PM   eBay Motors   #17 (permalink)
bigdawg1
what kind of tranny fluid do you put in filter??? i am off to autozone in a few minutes
Old 11-05-2009, 07:16 PM   eBay Motors   #18 (permalink)
D-MAX Mafia
Wide Open!!!
Just cheap stuff. It comes in a black bottle and looks really cheap! Buy 4 quarts put one in the filter and the other 3 in the tank.
06 CC/SB LBZ
I got a D-MAX Baby!
Tuned with EFILive
Old 11-05-2009, 07:22 PM   eBay Motors   #19 (permalink)
bigdawg1
thanks for info , the light did finally clear i will give update later
Old 11-05-2009, 09:49 PM   eBay Motors   #20 (permalink)
bigdawg1
Thanks For All The Great Info And Help , Changed Filter And Bought Scan Tool ... Code Was P0087 Low Fuel Rail All Seems To Be Great Now.
Chris
« abs | Winter Tunes »
