Old 11-05-2009, 06:28 PM   eBay Motors   #1 (permalink)
bigdawg1
need help 2006 lbz lost power ????
i have an 06 lbz that i just lost power , light came on and won't go over 20 miles per hour . no smoke or anything idles smooth , i have noticed the last week when i get on it in third-forth gear seemed a little slugish ???
is there a way to clear codes without scan tool so i can drive into a dealer atleast ????
i have no cat , 4" exhaust , kn filter , and no programer
bigdawg1 is offline   Reply With Quote
Old 11-05-2009, 06:32 PM   eBay Motors   #2 (permalink)
D-MAX Mafia
Wide Open!!!
D-MAX Mafia's Avatar
When was the last time you changed the fuel filter?
06 CC/SB LBZ
I got a D-MAX Baby!
Tuned with EFILive
D-MAX Mafia is offline   Reply With Quote
Old 11-05-2009, 06:34 PM   eBay Motors   #3 (permalink)
bigdawg1
i have had truck for 5000 miles only and computer says i am down to about 40 percent left?????
Old 11-05-2009, 06:37 PM   eBay Motors   #4 (permalink)
D-MAX Mafia
Wide Open!!!
Hard to say then? I'd change the fuel filter. The dealership or previous owner could have reset the computer with out doing the correct service!
06 CC/SB LBZ
I got a D-MAX Baby!
Tuned with EFILive
Old 11-05-2009, 06:38 PM   eBay Motors   #5 (permalink)
bigdawg1
is there a way to clear code ? with out computer
Old 11-05-2009, 06:40 PM   eBay Motors   #6 (permalink)
Johnasara
Yeah, That guy!!!!!
Johnasara's Avatar
You can try to disconnect the batteries for about 30 seconds it will reset anything minor. It sounds like a filter to me.
4" DIAMOND EYE EXHAUST,
DIABLO @ 120,S&B COLD AIR INTAKE, RESONATOR PLUGGED
AUTOMETER ULTRALITE GAUGES, TRANSGO JR, EGR BLOCKED!!!!285/75 BFGs ON ULTRA DYMONDS, TIE ROD SLEEVES....Its Coming.....EFI LIVE.....
WORK RIG
Johnasara is online now   Reply With Quote
Old 11-05-2009, 06:40 PM   eBay Motors   #7 (permalink)
D-MAX Mafia
Wide Open!!!
The only thing to try is unhook both batteries. But if the problem is still there the engine light will come back on! How many miles are on the truck?
06 CC/SB LBZ
I got a D-MAX Baby!
Tuned with EFILive
Old 11-05-2009, 06:42 PM   eBay Motors   #8 (permalink)
bigdawg1
45,000 miles on truck, is the fuel filter easy to change never done it on a chevy
Old 11-05-2009, 06:45 PM   eBay Motors   #9 (permalink)
Johnasara
Yeah, That guy!!!!!
Johnasara's Avatar
Super easy on the LBZ. Use your search here in site, there are several DIYs on it.
WORK RIG
Old 11-05-2009, 06:45 PM   eBay Motors   #10 (permalink)
D-MAX Mafia
Wide Open!!!
Your first time might be fun but yeah its on the passenger side of the motor. unplug the water sensor at the bottom of the filter and spin the filter off. Use a pair of channel locks to remove the water seperator and replace both o-rings. they will come with the new filter.
06 CC/SB LBZ
I got a D-MAX Baby!
Tuned with EFILive
« abs | Winter Tunes »
