Old 11-06-2009, 07:28 PM   eBay Motors   #1 (permalink)
Odyssey25013
What to Expect
Hey Guys,
So this morning was nice and brisk. When out to start up the truck and the glow plugs, which normally go out after 8-10 seconds, wouldn't turn off. After about a minute i just turned it on. After which the check engine light was on. Called the stealership to see whats up. They cant fit me in for a 30 second scan until Wednesday. Also started it up after the engine was hot and the glow plug light came on for five seconds then went out. Normally it doesn't even light up. Any ideas on the problem is? I'd like to prepare myself for another big hit before I go in.
2006 LLY LT3 EC/LB
Resonator Blocked
Air Box Modified
Whelen LINZ6's in the grill
Magnaflow Stainless 4" TurboBack
Odyssey25013 is offline   Reply With Quote
Old 11-06-2009, 07:29 PM   eBay Motors   #2 (permalink)
delong_1
truck for sale
delong_1's Avatar
most parts places will check the codes for free, if that helps you at all.
Nate
2 turbos, built trans, and some tuning.
Old 11-06-2009, 07:36 PM   eBay Motors   #3 (permalink)
Odyssey25013
Oil change tomorrow. Ill see if I can get it done there. I dont have any parts shops around here.
2006 LLY LT3 EC/LB
Resonator Blocked
Air Box Modified
Old 11-07-2009, 08:07 AM   eBay Motors   #4 (permalink)
Odyssey25013
Ok I got the code. its 0676 glow plug heater cylinder 6. What does this mean?
2006 LLY LT3 EC/LB
Resonator Blocked
Air Box Modified
