| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | 06-07.5 LBZ & LLY Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |  | |
05-05-2008, 08:35 PM
eBay Motors
#1 (permalink)
| | Member
| Tranny Upgrade? I have an 07 LBZ with an AFE Stage 2, 4" MBRP, and a PPE set on 160. Do I need to do a tranny upgrade cause someone told me the other day that I should start thinking about it. If so I am not looking a droping $$$$ into a tranny cause I havn't even had the truck a year yet. I am just looking for something that will not let me down, hold up, and won't break the bank. Any suggestion would be helpful.
Thanks,
Derek
__________________ 07 LBZ White crew cab, 4" MBRP turbo back and AFE stage 2 intake and a PPE Xcelerator set on 160 best investment by far its so fast. 20" Goliath wheels with 305/55 Nitto terra grapplers. |
| Advertisement
05-05-2008, 08:38 PM
eBay Motors
#2 (permalink)
| | DuramaxForum Fanatic
| Turn the PPE down if you like your wallet,anywhere over 100 on stock Allison might work,but will not last..
__________________ 2006 crew cab 4wd. LBZ 2500 hd,straight piped,resonator mod only so far,1978 Malibu 350/350 trans,3.73 rear,illegal like a MUG to drive on tha street now,2002 ex cab 1500 2wd. 5.3 liter w/superchip prog. ya know momma's grocery getter!!!Just added a Superchips Flashpaq,man,what a big diff,I was also shocked when I got 21.5 mpg while doing 55 of course.It is the easist to use,simple and 5 power settings,only around 300 bucks,get one it'll pay for itself in about three months...   |
05-05-2008, 08:49 PM
eBay Motors
#3 (permalink)
| | Duramax Forum Supporter
| x2 on the turn it down. If you want to run big power you will need a tranny upgrade. The PPE is rated at the crank so you should be able to run level 3 without a prob.
__________________ 05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, PPE Hot+2 ET Xcellerator, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust, Level Kit, Suncoast Stage IV w/ 1056 TC
05-05-2008, 11:52 PM
eBay Motors
#4 (permalink)
| | Moderator
| Yup I agree. You should go down to the level 2 (90HP) so your tranny wont go into limo mode. The smallest and cheapest upgrade you can do is get a transgo jr. That kit increases line pressure to get firmer shifts and the truck wont slip the clutches as easy. You can probably get the kit installed for about $300.00
__________________ 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 2 MTX 10in Subs & Punch 250amp in a custom box. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 265/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
05-06-2008, 05:13 AM
eBay Motors
#5 (permalink)
| | Duramax Forum Moderator
| before you spend on the JR kit save up and do a tranny kit and the reason i say that a JR kit is a excellent idea it's just your torque conveter is your next weak link and that will need to be upgraded also..do the TTS tranny kit $370 and TCS converter for $1300(TCS builds all of the Sun Coast converters)and that is good for roughly 600-700RWHP.thats what i did for my LBZ and i love the setup,shifts like stock but it holds the power and i'm running the PPE HOT ET+2 on level 7(425HP).
__________________ Pulling truck
05 LLY Chevy LS E/C L/B DRW
to much to list and more to come.
My Truck
2006 LBZ GMC SLE C/C S/B
Performance=PPE HOT ET+2,AirDog Fuel System,BD Manifold,AFE CAI,Quadzilla Commander,TTS Tranny kit w/t TCS Converter,Silverline Exhaust,Crank-It-Up-Diesel Tie Rod Sleeves and Centerlink,EGR Blockplate,i think it's ready for some pulls |
05-06-2008, 07:43 AM
eBay Motors
#6 (permalink)
| | Junior Member
| i got the ppe and mines set on 325 with a stock transmission and mine does just fine.
__________________ RIDE: 07 Silverado Classic Crew Cab ENGINE: Duramax/6 Speed Allision LBZ 6.6 LIFT: Ready Lift Leveling Kit ADD ONS: Smoked cablights, tail lights, and 3rd brake light, kenwood dvd and navagation, 10 in kicker l7, 500 watt kenwood amp, stainless nerf bars, chrome bug shield TIRES/WHEELS: 325 60 18 toyo open country ats on 18 in Diamo 16 carats PIPE:5 in mbrp exhaust with 6 in tip PROGRAMMER: PPE Xcellerator Hot+2 |
05-06-2008, 02:02 PM
eBay Motors
#7 (permalink)
| | Member
| it will ok on a stock trans but the problem you will have will be limping 5 th gear and burnouts will hurt it . i had mine set on 300 and it was good till i took it out and put a aftermarket trans it has 38000 miles on it |
05-07-2008, 04:56 AM
eBay Motors
#8 (permalink)
| the 6SP ally will last quite a while with the 300-350HP tunes but if you tear one apart after it's had those tunes run you will see the damage so evem if it doesn't feel like the tranny is slipping or damaging it is doing just that,when my i had my tranny work done i got to see first hand what a PPE does to a stock tranny.the first 3 and 4 levels of the PPE on the 6SP will last a very long time but aftet those levels your on your own.
My Truck
05-07-2008, 07:51 PM
eBay Motors
#9 (permalink)
| | Member
Join Date: Feb 2008 Location: Alberta CANADA, and proud of it!
| Quote:
Originally Posted by TYREBOYZ_DEMAXIN before you spend on the JR kit save up and do a tranny kit and the reason i say that a JR kit is a excellent idea it's just your torque conveter is your next weak link and that will need to be upgraded also..do the TTS tranny kit $370 and TCS converter for $1300(TCS builds all of the Sun Coast converters)and that is good for roughly 600-700RWHP.thats what i did for my LBZ and i love the setup,shifts like stock but it holds the power and i'm running the PPE HOT ET+2 on level 7(425HP). | Hi TYRE,
This setup is the closest thing I've seen to a full trans upgrade that is close to my budget. Thanks for the suggestions!
Where can I learn more about these parts?
Who sells these?
How many hours would a decent shop require to install the TTS kit and TCS converter?
Thanks
__________________ 2007 LBZ 2500HD LT2 CC SB 4x4 Red
Leer canopy, Aries Oval step bars, everything else stock.
Love this truck....HATE the fuel economy  yea yea, I know it's a truck, and YES I want the same mpg as a Civic |
05-07-2008, 08:08 PM
eBay Motors
#10 (permalink)
| IdahoRob here on the DF sells the TTS kit.
This sale was for april, but this will give you an idea of what the kit includes. Transmission Upgrade Special
| Advertisement
