| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | 06-07.5 LBZ & LLY Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |  | |
05-13-2008, 11:48 AM
eBay Motors
#1 (permalink)
| | Junior Member
| Trans lines leaking I have a 06 LBZ 6 speed with bullydog chip, exhaust, and shift kit. I have been running these for about 15,000 miles with no problem except the transmission cooler lines leaking. I have had them replaced by the factory twice. Is there any aftermarket lines or fixes that can handle the line pressure? They don't pour just drip a little. Between oil changes I might put a qt of fluid in trans. Has anyone heard of any of these lines blowing off. |
| Advertisement
05-13-2008, 01:08 PM
eBay Motors
#2 (permalink)
| | D-Zule Vin-door
| I have never heard of a trans line blowing off. There really isnt THAT much pressure going through the cooler. You could always try braided lines, but if its leaking at the fitting near the trans or cooler, you can double up on band clamps. |
05-13-2008, 01:16 PM
eBay Motors
#3 (permalink)
| | Junior Member
| No it is leaking around the rubber hose under the radiator. I am guessing that they put a short hose in there to keep down vibrations or make it easier to install. |
05-13-2008, 01:19 PM
eBay Motors
#4 (permalink)
| | D-Zule Vin-door
| And you say your losing a quart every 5000 miles? |
05-13-2008, 01:39 PM
eBay Motors
#5 (permalink)
| | Junior Member
| It is very close. They cleaned the skid pan off the last time I took it to the dealer and now the skid pan front diff is wet again. It has been about 3 months now and 1500 miles. I checked the fluid and it is a little lower but its hard to tell with this little of time since it was filled. |
05-13-2008, 01:48 PM
eBay Motors
#6 (permalink)
| | D-Zule Vin-door
| A rubber line only leaks for a number of reasons.........waitta minute. You said it was under the radiator right? And that it was very short, if not tight? I wonder if its rubbing the hose thin and causing it to leak....
May want to try getting a longer hose and zip tying it up somewhere so it wont rub. |
05-13-2008, 01:55 PM
eBay Motors
#7 (permalink)
| | Junior Member
| Yes it is a short hose. I will check the hose for rubbed spot tonight and see. |
05-13-2008, 01:59 PM
eBay Motors
#8 (permalink)
| | D-Zule Vin-door
| Hopefully thats what the problem is.  |
05-13-2008, 10:25 PM
eBay Motors
#9 (permalink)
| | Duramax Forum Moderator
| I think there are some others that are having this problem. Not sure if they ever found a fix though. Do a search on here and think there are a couple of threads talking about it.
__________________ KYLE
05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust straight piped, Level Kit, Suncoast Stage IV w/ 1056 Torque Converter and Allison Deep pan EFI Live Tuned by IdahoRob!!!!
05-14-2008, 03:38 AM
eBay Motors
#10 (permalink)
| | Member
| Mine leaked as well, Its a common problem I hear. But, mine leaked from the fitting or clamp, maybe yours is rubbing on something, like stated above. better get crawling. I have heard about them going severeal times. Chevy probably replaces the lines with the same crappy ones that leak in the firt place..
__________________ 2006 Silverado Duramax
Ext. Cab Short Bed.
MBRP 4" C/B SS
PPE
Hummer wheels with 285/70/17 Nitto Terra Grapplers
Whelen amber strobes on back rack with amber strobes in the grille.
Back Rack
Boss Plow |
| Advertisement
