| 06-07.5 LBZ & LLY Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |
| Junior Member Join Date: Feb 2008 Location: Peoria , AZ
| Serpentine Belt Removal I have searched about removing the serpentine but have not found what I needed. On my 2006 the tensionor is on the bottom and I can't seem to get a breaker bar or rachet on it because of the fan shroud and the pipe that I think goes to the intake heater. Does anyone have any helpful hints on how to get the bar on it? I don't want to take it to the dealer for this? Thanks for any input.
__________________ 2011 CC 4x4 6.0 R.I.P. 2006 LBZ Chevy Duramax ![]() All stock with the exception of running 285's |
| Senior Member Join Date: Aug 2008 Location: Kirkland, Washington
| Different then then 05'? I use a 24" 1/2"drive breakerbar with a wooden block and it moves around quite nicely. The tensioner is on the upper left as you look at from the front on mine.
__________________ Mark ![]() 2005 4x4 3500 SRW CCLB LT, 120K+ 4" MBRP SS Cat back, aFe MP Nitto Terras on 17" Moto Metal 950 DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource |
| Yah Mark , mine is on the lower left side ( passengers side ). My friends 01 is like ur on the top. I know they make tools for this but I have never had to rent one - just use ur rachet and ur done. This is just going to be a pain in the a**.
| Senior Member Join Date: Jul 2009 Location: New Windsor, ny
| i'd like to bump this up im gonna be changing my belt and idler pulley end of the week
__________________ '06 GMC EC/SB LBZ: 2" resonator plug, EGR blocker, Autometer Boost & Pyro, air box mod, MBRP 4" straight piped, AFE 3" IC tube, 4.5" bills custom intake, Trasngo jr, Tie Rod sleeves, EFIlive V2 DSP5, mini lift w/bilsteins on 33's, 437hp/790lb-ft '05 GMC CC/LB/DRW LLY:(dads) EGR blocker, Autometer Boost & Pyro, AFE 4" TB w/muff, S&B intake, AFE bladerunner, AFE 3" IC tube, EFIlive V2 DSP5 tuned by Rob Coddens @ www.atptrucks.com |
| On the new LML vehicles they made it much harder to change the belt -- in fact, the GM book time is 1 hour to change the belt-- Might be easier on those to remove the shroud.
| Oh...... Squirrel! ![]() Join Date: Oct 2006 Location: Irwin PA
| Id just use a utility knife.. Comes off very easy ![]() I never looked honestly. Ill have to check on my truck tomorrow.
__________________ Jason ![]() 2006 Silverado 2500HD LBZ CC SB Exterior: Escalade Handles, Front windows tinted to match the rear, painted bumpers & mirrors, billet grille, 285/70/17 Nitto Crossteks on Pro Comp Wheels, Cognito Braces, Stainless Sleeves, Train Horns Interior: 4 Kicker 10in Subs in 2 custom box's, Autometer Ultra lite II Pyro and Boost gauges, Aeroforce Interceptor Gauge, HID Lows & Fogs, Painted accents Performance: EFI Live Tuned by Blackout Performance, Custom Blackout Performance S475 over stock twins, 45 over stock injectors, MBRP Turbo Back Stainless Exhaust (Straight piped), Raptor Lift Pump, AFE Filter, GMAX6 kit with Suncoast 1057 converter installed by Blackout Performance 1999 Ford F-550 PowerStroke ''Wrecker'' **Jerrdan bed, S&B Intake |
