Ckeck engine light on 06 Duramax LBZ - Chevy and GMC Duramax Diesel Forum
Old 07-15-2010, 03:32 PM   eBay Motors  #1 (permalink)
We are heading west on I40 from North Carolina pulling a Cameo 35sb2. I stopped about 150 miles from here at a Flying J to fill both tanks. and pulled into Albuquerque, NM into a campground. Everything fine no check engine light and running good. This morning I checked the oil and it was a quart low, so I added a quart. When I started it I got a steady check engine light. I have checked the fuel caps and oil cap and dipstick and everything OK. Any ideas on something else to check ? It still running good , no smoke as good as ever. I do plan to top off the fuel tomorrow before heading to Williams , AZ or should I see a Chevy dealer first ? The truck has 58,000 miles on it.
bearnc1 is offline   Reply With Quote Quick reply to this message
Old 07-15-2010, 03:34 PM   eBay Motors  #2 (permalink)
Administrator
ob_1jr's Avatar
I would go to autozone or some other parts store and have them read your codes....most of them do it for free. Dealers might charge big time just to download the codes.
BTW, Welcome to the forum.
SOLD
305/70-16 BFG T/A KOs on Eagle Alloys Series 187
Clifford remote start. High Idle, Bilstein 5100s, 1.5" lift blocks
CAT fuel filter w/ nicktane adapter
Magnum Force Stage 2 intake with AMSOIL filter
Racor 2 Micron pre-OEM with heater & water sep
Lightforce 140s from Madjackracing
http://WWW.ATPTRUCKS.COM/
ob_1jr is offline   Reply With Quote Quick reply to this message
Old 07-15-2010, 03:36 PM   eBay Motors  #3 (permalink)
DuramaxBuilder's Avatar
x2 welcome to the forum, like ob_1jr said most of all your parts stores will scan your truck for free, good luck and have a safe trip
Chris
01 Chevy 2500HD Dmax, 4x4, Reg. Cab Long Bed, SAS Dana 60 HP Kingpin. 10 inches , np 241 x case modded, 400,231 miles on it org. motor
03 Chevy 2500 HD CCLB. 16x10 Black Bead locks Stock with 271,000 miles
www.GetSomePerformance.com , Dont you think its time you got some!
DuramaxBuilder is offline   Reply With Quote Quick reply to this message
Old 07-15-2010, 05:16 PM   eBay Motors  #4 (permalink)
Turbo vane sensor..
I just got a check engine light on my '06 LBZ with 65000 miles about a month ago while towing. No obvious problem, just a slight loss of power. It was a code for the turbo vane sensor. Not covered by warranty, $850.00. GMC claims it is part of the emissions, which is only covered to 50,000 miles, even though it controls the turbo.
After doing some research it seems this is a common problem on the LBZs starting about 50,000 miles. Also, the turbo vane solenoid goes out at about the same time. I'm in the process of changing mine now just to prevent future problems. The cost is about $190.00 if you do it yourself.
Tom W is offline   Reply With Quote Quick reply to this message
Old 07-15-2010, 07:37 PM   eBay Motors  #5 (permalink)
I just got back from Auto Zone and the code 661, 662 and 663. The circuit to the glow plug open shorted or bad glow plug. Anyone know here I can look?
Old 07-15-2010, 08:40 PM   eBay Motors  #6 (permalink)
viejajefita's Avatar
Little late in the evening but here is a bump for ya. You never know who is watching at this hour.
'06 2500 HD cc 4x4 Allison trans
Edge Evo Race level 2
265/75-16 BFG's
LBZ w/200k+ seen as high as 21mpg and as low as 8mpg
PPE free airbox mod from DIY sticky Firestone bags married to Ride Rite comp and gauge
Clinton lied. A man might forget where he parks or where he lives, but he never forgets oral sex, no matter how bad it is.
Barbara Bush
viejajefita is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 07:02 AM   eBay Motors  #7 (permalink)
I have looked at the connections and can't find anything loose. I even unpluged a few and reseated and still got the check engine light.
Old 07-16-2010, 07:19 AM   eBay Motors  #8 (permalink)
Super Moderator
jc1843's Avatar
LBZ engines seem to have problems with the Glow Plugs- GM covers them with warranty for 100k or 5 years.
It does not hurt to drive it , but will be harder to start in cold weather.
Chevy 04.5 LLY, 2X, shell, XDR, MikeL Heavy duty up-grade, 6spd, TransGo, deep pan, de-badged, 65 Gallon replacement Aero tank, LBZ-mp, Kennedy pump, shimmed, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags, custom grille, fender vents, HD trans cooler- Curt front hitch, footwell lights, load lights, Studs, head gaskets.--- Jerry
jc1843 is offline   Reply With Quote Quick reply to this message
Old 07-16-2010, 08:47 AM   eBay Motors  #9 (permalink)
I did a cold start this morning and the glow plug light does not go out until after the engine is started. I am going to let this wait until I get home in a couple of months. thanks everybody!!!
Old 07-16-2010, 09:10 AM   eBay Motors  #10 (permalink)
knaffie's Avatar
FYI, there was a recall that had something to do with the glow plugs. Probably a free fix!
06 CCSB LBZ 4x4 LT3; torsion key lift (leveled); 265/75-16 Pro Comp A/T on OEM wheels (winter), BFGoodrich Rugged Terrain 275/70-18 on XD Diesel 18x9 (summer); MBRP 4" turbo back with Corsa muffler; EGR blocked; Edge Insight CTS gauges; EFI Live DSP2 by Idaho Rob - 80HP DD and 40HP tow with turbo brake (love it!); Rancho 9000XL shocks; updated rear cab mounts; Transgo Jr.; Merchant Automotive tie rod sleeves; everything synthetic; Access Tonneau hiding Line-X; tinted windows 5% all around; Tekonsha P3 brake controller; HIR bulbs, more to come soon......
knaffie is offline   Reply With Quote Quick reply to this message
Insurance
