LBZ Down Pipe?? - Chevy and GMC Duramax Diesel Forum
Old 12-05-2010, 06:08 AM   eBay Motors  #1 (permalink)
LBZ Down Pipe??
I want to do a down pipe but a hear its a real pain in the ass...Any of you guys got them? how hard are they to install? Are they worth it??
06 GMC CC Dually LBZ
EFI Live, S&B intake, EGR Blocking plate, PCV reroute, 4" MBRP straight pipe.
7984 lbz is offline   Reply With Quote Quick reply to this message
Old 12-05-2010, 06:11 AM   eBay Motors  #2 (permalink)
Slave to the Interwebs
Johnasara's Avatar
I am also in the same boat. I hear they drop the EGTs a couple hundred degrees.
WORK RIG
2014 3500 CREW,DUALLY, LML, HARBOR 9' UTILITY BED Bone Freakin Stock
Johnasara is online now   Reply With Quote Quick reply to this message
Old 12-05-2010, 06:14 AM   eBay Motors  #3 (permalink)
Vrabel's Avatar
Yes it's definitely worth it. one of the smarter first mods. can be fun to install.
R.I.P.
2001 Chevy CC/SB 4WD EFI Live DSP 5, LBZ Short Block, Cut LB7 Pistons,keyed crank and cam, balanced,LBZ Intake Runners with RDL Shorty Y-Bridge, EPR Twins, Big Dipper 40% overs, MBRP Cool Duals, LBZ CP3, ADII, BD Manifold, C2 Gauges, H2 Wheels, Cognito Sleeves and Braces, Hids-Hi-Low-Fogs.
Sheet Metal Workers Local #22
If it's not made in America, YOU paid too much!
Creatures of The Night Performance and ProFab Performance
Vrabel is offline   Reply With Quote Quick reply to this message
Old 12-05-2010, 07:51 AM   eBay Motors  #4 (permalink)
Porno Joe's Avatar
I just did this last week. def worth it. looks like egts dropped a few degrees and the truck is louder. As far as the install goes, its not that bad, the shield on the turbo doesnt come out, so i cut mine in half and just left it off. I think it took me a total of bout 3 hours, and i had my dad help me position the new one in place.
2007 GMC 3500 LBZ- built trans, TCT 466, dual pumps, studded one at a time, running a Fluidamper
Porno Joe is offline   Reply With Quote Quick reply to this message
Old 12-05-2010, 08:45 AM   eBay Motors  #5 (permalink)
Banned
2 V ban clamps, 3 12mm turbo heat shield bolts, and 1 17mm bolt and the downpipe is off, pretty easy actually.
Not true. no difference in stock other than idling EGT's after driving.
Hondarider552 is offline   Reply With Quote Quick reply to this message
Old 12-05-2010, 08:53 AM   eBay Motors  #6 (permalink)
llypower's Avatar
i did mine when I had to do the hg's on my truck, It was easy then. I didnt see much improvement, but my truck is quieter at idle now.
2006 gmc ccsb
Built frontend, s366, mark at danville dsp5
2004 LLY GMC
650hp-SOLD
llypower is offline   Reply With Quote Quick reply to this message
Old 12-05-2010, 08:54 AM   eBay Motors  #7 (permalink)
Stupid Has The Balls
Odyssey25013's Avatar
You seem so sure of this....why would my egts drop on the same 7 mile stretch of highway. 700-750 down to 600-650.....yea same conditions mid summer 85* weather
Ben
2006 LLZ LT3 EC/LB
"Going for Broke"
Some Expensive Parts, Good Times, Busted Knuckles, Long Nights and Fancy Gauges So I Can Watch While I Blow Things Up
Special Thanks To Ben Tyler at BT DieselWorks, LLC. For All The Help and Hard Work
Odyssey25013 is offline   Reply With Quote Quick reply to this message
Old 12-05-2010, 09:00 AM   eBay Motors  #8 (permalink)
Banned
Inaccurate guage readings, etc. I had 2 different EGT probes in my motor before and after I put a D.E. downpipe on, and only change was idle egt, and after a WOT run and then back to 300egt. Cruising was exactly the same; I cannot see how a 3' piece of pipe reduces egt's 50-150* with the same amount fo fuel coming out of the motor. With the tests that I did, it proved what I thought. but then again, im not Killlerbee
Old 12-05-2010, 09:01 AM   eBay Motors  #9 (permalink)
jbrown1132's Avatar
some say the down pipe makes the truck louder, some say it makes it quieter. i have the down pipe and about to do the install, just curious as to the difference in the sound.
'05 GMC 2500HD (white) slt cc sb 4x4
efi-tuned by idahorob, egr blocked, pcv rerouted, lift pump, kodiac mp,autometer sportcomp gauges, turbo dp, 4" ss magna flow exhaust straight piped, firestone ab, kool-vue towing mirrors, 5th wheel hitch with slider, gooseneck hitch.
305 MT ATZ's on eagle alloy 17x10
jbrown1132@yahoo.com
alligatorperformance.com
atptrucks.com
Truck is sold....
jbrown1132 is offline   Reply With Quote Quick reply to this message
Old 12-05-2010, 09:04 AM   eBay Motors  #10 (permalink)
Banned
On my truck it made it louder a bit at idle, and got rid of 75% of the WOT screech and more like a 6.0 ford; IMO.
Insurance
