Head gasket leaking? - Chevy and GMC Duramax Diesel Forum
Old 12-07-2010, 06:06 PM   eBay Motors  #1 (permalink)
scarboroughhb22's Avatar
ive got a 06 LBZ that I bought in august and has been great! put it on the lift at work about a month ago and looked over everything and noticed oil leaking from the rear of the passenger side head right where the head and block meet. now i checked everything and ive got no symtoms of a blown head gasket. I cleaned the oil off and checked it last week and still wet around it with oil. anyone experience this before or know what i can do?
06 LBZ
12.8 1/4
EFI live DSP5
transgo jr
S&B intake
5" exhaust
Fass 150
EGR delete
PCV reroute
scarboroughhb22 is offline   Reply With Quote Quick reply to this message
Old 12-07-2010, 06:10 PM   eBay Motors  #2 (permalink)
Super Moderator
jc1843's Avatar
Might be the PCV syatem dumping oil into the Turbo and pushing it out-- common to have oil in the boost system. You can reroute the system and the engine will stay cleaner!
Also another possibilty is a leaking valve cover gasket, or a turbo drain tube. You need to inspect it closer.
Chevy 04.5 LLY, 2X, shell, XDR, MikeL Heavy duty up-grade, 6spd, TransGo, deep pan, de-badged, 65 Gallon replacement Aero tank, LBZ-mp, Kennedy pump, shimmed, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags, custom grille, fender vents, HD trans cooler- Curt front hitch, footwell lights, load lights, Studs, head gaskets.--- Jerry
jc1843 is offline   Reply With Quote Quick reply to this message
Old 12-07-2010, 06:12 PM   eBay Motors  #3 (permalink)
born country
Dmaxryan10's Avatar
man i don't know, i would think it would be coolant not oil comin out, since the coolant would get through easier, are you sure it's not comin from somewhere else and just collecting there? could be the egr leaking or something. i don't know though sorry.
NEW TRUCK- 2006 LBZ cc/sb loaded southern coach, smoky mountain sportsman edition, 20" black hostile havoc's, 305/50/20 nitto trail grapplers, EFI LIVE by rob at ATP performance, 5" exhaust, transgo jr, egr blocked, pcv rerouted, isspro ev2 gauges, tinted windows, just gettin started!
Dmaxryan10 is offline   Reply With Quote Quick reply to this message
Old 12-07-2010, 06:19 PM   eBay Motors  #4 (permalink)
ive got the pcv reoute and egr block. i used brake cleaner and made sure it was all clean and dry a month ago and its wet right where the head and block meet.
06 LBZ
12.8 1/4
EFI live DSP5
transgo jr
S&B intake
5" exhaust
Fass 150
EGR delete
PCV reroute
Insurance
