Old 07-17-2008, 10:53 AM   eBay Motors   #1 (permalink)
Fortuna
Points: 1,044, Level: 12
Points: 1,044, Level: 12 Points: 1,044, Level: 12 Points: 1,044, Level: 12
Activity: 0%
Black Smoke
I have a 2500HD 2007 LBZ had it to dealerninstalled #4 injector 23,000mi. If I punch it I get black smoke. any suggestions???
Fortuna is offline   Reply With Quote
Old 07-17-2008, 11:28 AM   eBay Motors   #2 (permalink)
Tow Master
Late Night Post Whore
Points: 12,368, Level: 48
Points: 12,368, Level: 48 Points: 12,368, Level: 48 Points: 12,368, Level: 48
Activity: 89%
Activity: 89% Activity: 89% Activity: 89%
Tow Master's Avatar
Do you have anything done to it? exhaust, programer, intake etc.? Does it run bad? So your saying you dont want it to smoke?
Even stock trucks will smoke a little when you nail it. The 06+ shouldnt hardly smoke at all!
Jason
2006 Silverado Shortbed Crew Cab LBZ
Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights
4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod
MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2
Lost Kitty Reward if found!!
1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake
Old 07-17-2008, 05:49 PM   eBay Motors   #3 (permalink)
Fortuna
Activity: 0%
Stock with the exception of K&N filter
Old 07-18-2008, 12:18 AM   eBay Motors   #4 (permalink)
BigRedChevy
The Real Post Whore
Points: 10,778, Level: 44
Points: 10,778, Level: 44 Points: 10,778, Level: 44 Points: 10,778, Level: 44
Activity: 100%
BigRedChevy's Avatar
I would clean the MAF sensor. The K&N is known for letting oil into the intake and messing with the MAF sensor.
KYLE
Old 07-18-2008, 01:50 AM   eBay Motors   #5 (permalink)
TheHoov
Points: 3,111, Level: 23
Points: 3,111, Level: 23 Points: 3,111, Level: 23 Points: 3,111, Level: 23
Activity: 0%
TheHoov's Avatar
I had a K&N drop in filter and it really messed up the MAF. I don't know if that has something to do with the black smoke thought.
2002 Chevy LB7 Crew Cab
Thank you Duramax Forums
TheHoov is offline   Reply With Quote
Old 07-18-2008, 05:31 AM   eBay Motors   #6 (permalink)
Johnasara
Points: 4,176, Level: 27
Points: 4,176, Level: 27 Points: 4,176, Level: 27 Points: 4,176, Level: 27
Activity: 13%
Activity: 13% Activity: 13% Activity: 13%
Johnasara's Avatar
If it is not a whole lot of black smoke then it is normal. My LBZ does the same. I was actually surprised when I nailed it with the mods, there was not a whole lot of smoke.
06 2500 CREW CAB 4X4 LBZ
4" DIAMOND EYE EXHAUST, KITTY RAN OFF!!!
DIABLO @ 120HP. 285/75 BFG's RUNNIN ON ULTRA 16's
PIONEER HEAD UNIT RUNNIN SCOSCHE AMP W MTX TWINS
AIR BOX IMPELLER REMOVED!! RESONATOR PLUGGED !!!
AUTOMETER ULTRALITE GAUGES IN POD. TRANSGO JR
WORK RIG
O7.5 3500 CREW, LMM, ROYAL UTILITY BED
4" DIAMOND EYE EXHAUST.DPF???KITTY?? QUADZILLA PROGRAMMER. MTX AMP AND 10" TWINS IN THE BACK. STEPS,VISORS,BUG SHEILD. AIRBOX IMPELLER REMOVED,RESONATOR PLUGGED,LOTS OF PRETTY DIAMOND PLATE EVERYWHERE
Old 08-26-2008, 12:40 AM   eBay Motors   #7 (permalink)
06CHROMECHEVY
Points: 544, Level: 8
Points: 544, Level: 8 Points: 544, Level: 8 Points: 544, Level: 8
Activity: 0%
what would be suggested to clean the MAS?
06CHROMECHEVY is offline   Reply With Quote
Old 08-26-2008, 06:00 AM   eBay Motors   #8 (permalink)
TYREBOYZ_DEMAXIN
Experienced Post Whore
Points: 10,947, Level: 45
Points: 10,947, Level: 45 Points: 10,947, Level: 45 Points: 10,947, Level: 45
Activity: 100%
TYREBOYZ_DEMAXIN's Avatar
do not touch the MAF with your hands since the oil from your skin will damage it..the LBZ will smoke a little after it's been driven at the same for a while or has been idleing you mite say its just cleaning out the exhaust a little when you hit it after it has been running without a WOT run for a period of time,also it gets a little worse with a straight exhaust..
James
I HAVE THE MEDAL
Old 08-26-2008, 09:32 AM   eBay Motors   #9 (permalink)
gr8shot
Points: 2,301, Level: 19
Points: 2,301, Level: 19 Points: 2,301, Level: 19 Points: 2,301, Level: 19
Activity: 8%
Activity: 8% Activity: 8% Activity: 8%
gr8shot's Avatar
They sell MAF cleaner at most part stores. Soak it good, let it dry then your good to go.
Old 08-26-2008, 11:39 PM   eBay Motors   #10 (permalink)
DMax07LBZ
Points: 292, Level: 5
Points: 292, Level: 5 Points: 292, Level: 5 Points: 292, Level: 5
Activity: 0%
DMax07LBZ's Avatar
my lbz with 33000 stock smoked alot at night for sum reason now i str8 piped it put an xdi intake and juice and i looove the smoke it leaves no tailgaters behind me now
2007 Silverado Duramax LBZ Crew Cab
Escalade handles, Bedrug, Painted bumpers and mirrors, 5% Tint All around, 20% Tint on Windshield, Smoked Tail lights and 3rd Brakelight
2 Fosgate Shallow Mount Sub's, Alpine IVA-505, Diamond Audio Components, 2 TUNN 1,300 watt Amps, 6 Tv's Total
RBP Turbo Back Exhaust. Edge Juice with Attitude, Trueflow XDI Air Intake, Resignator Plug
Clifford SST 2-Way Alarm with GPS Tracking & Remote Start, H.I.D Headlights
Pro Comp Level Kit, Bilsetin 5100 Shocks All Around
Helo Max Wheels Black, 33inch Mickey Thompson Baja Claw Radial
DMax07LBZ is offline   Reply With Quote
