ticking knocking sound getting worse help - Chevy and GMC Duramax Diesel Forum
Old 01-06-2011, 12:09 PM   eBay Motors  #1 (permalink)
lbzwoods's Avatar
a wile back i heard a very slight ticking noise wile pulling up to the gate on base or a drive through, and thought it was the common ticking noise. it pissed me off but i accepted it. but the sound has gone from a faint ticking to a very loud tick / knock.i have noticed it will do it when
1 truck is just turned on it will make the noise for 5-10 seconds
2 truck is just turned off it will make the noise for 5-10 seconds
3 slowing down to stop at a stop light useing brakes or coasting does it till 5-10 seconds after complete stop
4 slowly creaping through traffic or a drive through constant till rpms raise any or 5 seconds after stopping
5 jerking the throttle (barely power braking) wile holding brake down
i am at a loss here exhaust heat shields are all tight truck 2006 lbz with bd drivers side manifold rdl up pipes and diemond eye down pipe allison 6 speed w/ transgo jr shift kit and 1056 suncoast converter please help
06 CCSB LBZ, EFI Live, SoCal, ARP, SDP, AFE, BD, PPE, RDL, Air Dog, MBRP, Suncoast
lbzwoods is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 05:41 PM   eBay Motors  #2 (permalink)
lbzwoods's Avatar
any help? im seriously freakin out here
Old 01-06-2011, 05:43 PM   eBay Motors  #3 (permalink)
BUBBA3M's Avatar
It may be noraml, does this bulletin describe it?
Duramax Ticking
Bulletin No.: 02-06-01-022H
Date: August 18 2008
Subject:
Information on Engine Ticking Noise
Models:
2001-2007 Chevrolet Silverado (Classic)
2003-2009 Chevrolet Kodiak C4500/C5500 Series
2006-2009 Chevrolet Express
2001-2007 GMC Sierra (Classic)
2003-2009 GMC TopKick C4500/C5500 Series
2006-2009 GMC Savana
with 6.6L Duramax(TM) Diesel Engine (VINs D, 1, 2 - RPOs LBZ, LB7, LLY)
Supercede:
This bulletin is being revised to add model years and remove RPO LMM. Please discard Corporate Bulletin Number 02-06-01-022G (Section 06 - Engine/Propulsion System).
Some of the above vehicles may exhibit a random ticking noise that is most audible on an engine with a coolant temperature of 70C (158F) or higher and from idle to approximately 1500 RPM. The noise usually is most noticeable at the rear of the drivers side front wheel well. Customers may also comment about hearing a tick noise inside the vehicle at idle such as when sitting at a drive through window. All 6600 Duramax(TM) diesel engines have this condition; however some are more audible than others. Engine build variation from engine to engine contributes to differences in perceived volume. All Duramax(TM) engines are manufactured to very close tolerances to meet the durability and reliability standards.
This noise is caused by the relationship of the engine cylinder block crankshaft journals bearing inserts and the oil film. This relationship may allow a vibration that resonates through the cylinder block and is heard as a metallic ticking noise. The noise could be described as an irregular ticking or clacking sound like random typing on a mechanical typewriter.
This condition has been present in diesel engines produced for the last 20 or more years. The overall noise reduction in engines produced today makes this noise seem new when in fact it was masked by other noises in the past. Many manufacturers such as Isuzu Hino Mitsubishi and Nissan report a similar condition in their diesel engines. Testing and engine teardowns with this condition reveal no condition that would affect reliability or durability of this engine.
Dealers should not attempt to compare any customer vehicles exhibiting this noise with other similar vehicles as the noise is different from vehicle to vehicle and this may lead to the incorrect conclusion that the vehicle has a condition. This noise is a normal operating characteristic of the engine. This noise has no short or long term effects on the engine. Do not attempt repairs for this noise.
Important: Replacing the engine or internal components for this noise will not reduce or eliminate the noise.
2013 LML, 6 spd Ally, CC/SB, Bone Stock
2006 LBZ SOLD
EFI Live V2, DSP 5 by Idaho Rob
3" MBRP Turbo DP
4" MBRP Exhaust
MBRP Hot Side IC Pipe
PPE IC Boots
BD Full Bore Exhaust Manifolds
SDP EGR Delete
PCV Reroute
TCase Pump rub fixed
Autometer Gauge Pod w/ Boost and EGT Cobalt Gauges
Bilstein 5100"s
2008 Copper Canyon 30ft 5th wheel
BUBBA3M is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 05:44 PM   eBay Motors  #4 (permalink)
born country
Dmaxryan10's Avatar
do you run any fuel additives?
NEW TRUCK- 2006 LBZ cc/sb loaded southern coach, smoky mountain sportsman edition, 20" black hostile havoc's, 305/50/20 nitto trail grapplers, EFI LIVE by rob at ATP performance, 5" exhaust, transgo jr, egr blocked, pcv rerouted, isspro ev2 gauges, tinted windows, just gettin started!
Dmaxryan10 is offline   Reply With Quote Quick reply to this message
Old 01-07-2011, 12:11 AM   eBay Motors  #5 (permalink)
lbzwoods's Avatar
Duramax Ticking
Subject:
no it does not there used to be a very sight noise and i knew about the bulitin but then it has gotten much louder instead of random typing on a mechanical typewriter it sounds like a mechanical typewriter is in an industrial blender for the previously stated time
yes i do ive been running the same xdp additive for the last 20,000 miles along with reguar rotella oil changes
Old 01-14-2011, 06:20 PM   eBay Motors  #6 (permalink)
lbzwoods's Avatar
bump... any help?
Old 01-17-2011, 07:23 PM   eBay Motors  #7 (permalink)
lbzwoods's Avatar
bout to pull the trans to see if the flex plate is messed up
Old 01-20-2011, 03:11 PM   eBay Motors  #8 (permalink)
lbzwoods's Avatar
cracked flexplate... and all the torque converter bolts are still torqued soo ats billit steel flexplate on order fml
Old 02-17-2011, 06:12 PM   eBay Motors  #9 (permalink)
johnboy05's Avatar
Hmm Sounds like i have the same problem Would it still be okay to drive on it for awhile? taking it easy of course, i never noticed mine until a week ago. exact same sound as what you are describing
2011 LML Denali completely stock.... for now
SOLD
2007 LBZ duramax EFI Live tuned by rob,NADP heavy hauler tranny, AFE intake 4"straight pipe turbo back. Castflow maifolds and 2" up pipes as well as RDL EGR delete pipe, airdog II 165, suncoast billet flex plate, pyro/ boost gauges, MBRP down pipe, 4094 AVNT, 60% nozzles.
johnboy05 is offline   Reply With Quote Quick reply to this message
Old 02-17-2011, 07:03 PM   eBay Motors  #10 (permalink)
ATPTRUCKS
sickdiesel's Avatar
is this normal lol does this happen alot?
Blackout :06 GMC lbz 4x4 Built motor, HSP twins, DDP Injectors, Self built trans 11.68@118.5
Over Built :07 Chevy lbz 4x4 Caged and built 10.42@134
The Car: 2014 Chevy Cruze 2.0 Diesel
Special thanks to: Mike L, Gtrippin, IdahoRob, Dmaxstore, HSP, ISSPRO, Yukon, Airdog
LIKE US ON FACEBOOK!
Adrenaline Truck Performance IDAHO ROB 208.685.1000
sickdiesel is offline   Reply With Quote Quick reply to this message
Insurance
