| Premium Membership | |
| | | 06-07.5 LBZ & LLY Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |  | |
01-31-2007, 06:27 PM
eBay Motors
#1 (permalink)
| | Junior Member
| '06 turbo makes noise when engine shut off My '06 has 12k miles on it. At about 9k I noticed that after shutting the truck off I would hear the turbo spin down and it sounds almost like the bearings are going bad. It's not loud at all and can only be heard if its quiet outside. I took it to the dealer and they said it was not unusual and not to worry about it. They brought a new truck in the shop and set it next to mine and shut it off for comparison. I could hear it spin down but nothing like mine. Has anyone else noticed this noise?
If someone has an '06 or '07 could someone let me know if your truck makes no turbo spin-down noise at all? I'm worried this is not normal an it's going to come apart soon... thanks in advance
Reason: asking for help
| Advertisement
02-02-2007, 07:32 PM
eBay Motors
#2 (permalink)
| | Junior Member
| My '06 is making the turbo noise also when shutting the engine off. It has about 5100 miles, but I have not checked in to it yet. |
02-02-2007, 07:55 PM
eBay Motors
#3 (permalink)
| | Gear Jammer...
| All of the 06 trucks ive heard do it also, even my 05 and 04 do it. THe sounds are even louder after adding a aftermarket air intake!
__________________ 05 Chevy 2500HD dark blue reg cab ZF-6 speed/W South Bend Clutch ,Power by EFI Live W/Dsp2 , PPE GT4094R, ATS CP3x2, Modified Volant intake, MBRP front pipe, 4" side pipe, Holley Blue lift pump, Isspro gauges,Cognito Braces, SD Centerlink, Caltracs, ATS Tie Rod Sleeves Best ET 12.53@ 109 mph 04.5 Chevy 2500HD, silverbirch, D/A, CC/SB , EFI live, SCIV w/ATS 5Star converter,McRat shim mod, Wicked Diesels modded FPR, Kennedy dual lift pump, Modified Volant intake, Cognito Braces,CUD tie rod Sleeves, EGR BLocker,Diamond eye Down pipe, 4" dual exhaust, Elocker, MA Tcase Fix, B&W GN Hitch Best ET 13.53 @ 101mph |
02-02-2007, 09:22 PM
eBay Motors
#4 (permalink)
| | Member
| I havent noticed but then again I am around bigger trucks with way bigger engines and turbos all day long so my hearing is not so well anymore. I do hear a squeeking sound like a slipping fan belt when I shut mine down, but havent heard the turbo wind down.
__________________ 2006 2500HD Extended Cab Short bed 4X4 LBZ Gray-stone Metallic, MBRP 4" down pipe back no filter, Edge juice w/ atttitude, Banks ram air intake and one dent where the wife jackknifed the utility trailer |
02-03-2007, 08:04 AM
eBay Motors
#5 (permalink)
| | Junior Member
| Thanks to everyone that responded. It's good to know that this sound is something normal. This is my first diesel, in fact the first I driven. I made the mistake of thinking my '02 GMC 2500hd with the 6 liter gas engine could pull my new 10k lb. 5th wheel trailer here it the mountains of Colorado. I'll never buy another gas engine truck again. |
02-13-2007, 01:54 PM
eBay Motors
#6 (permalink)
| | Junior Member
| If the noise you hear is coming from the turbo area it could be the variable vanes on the '06 turbo. Know if you think it's from the front it is the fan belt. Their is a TSB for this and the dealer will install a "clutched" alternator. Some folks had great results with replacing the belt with a Goodyear Gatorback.
__________________ Ray Lopez
2006 Silverado "Grey Ghost" 2500HD CC/SB
295/70/17 Terra Grapplers/H2's Chome
5" Magnaflow Cat-Back
LBZ Edge/Attitude |
02-14-2007, 05:26 PM
eBay Motors
#7 (permalink)
| | Junior Member
| I've got that sound too. I thought the sound was more like a jet motor winding down. I'm more concerned about my detonation sound since I've installed my programmer.
__________________ 2006 LBZ CC
PPE Xcellerator
Pyrometer
Bilstein Shocks
4" MBPR Catback
Firestone Ride Rite Air Bags
Bushwacker Pockets
Escalade Door Handles
Billet Grill
305 Cooper on Hilo's |
04-12-2007, 09:09 AM
eBay Motors
#8 (permalink)
| | Senior Member
| i want this so called turbo wind down sound how do i get it
__________________ 2006 LLY with some miles
-EFI Live(Best Investment Ever!!!!)
-Turbo-Back RBP 4" with no muffler and my cat ran away
-limo tinted windows all the way around except winsheild
-18"MKW M25 with 285/65/R18 Toyo A/T
-Afe replacement filter
-Cogneto Leveling Kit |
04-12-2007, 12:00 PM
eBay Motors
#9 (permalink)
| | Junior Member
| noisey turbo Well, if you want the sound - take 2, 1/2 inch ball bearings and put them in a empty coffee can and swirl them around the bottom of the can..... then you'll have an idea what is sounds like. |
04-12-2007, 01:51 PM
eBay Motors
#10 (permalink)
| | Duramax Forum Moderator
| Quote:
Originally Posted by idrivebowtie i want this so called turbo wind down sound how do i get it | put a straight exhaust on that baby and you'll hear that turbo all time,while it's runnin that is
__________________ James
My Truck now,1987 Chevy 2500 350 tweaked,6" SuperLift,350 V8 bored 60 over,Elderbrock headers Cam and Titanium Rockers,750 Twin Pumped Holley Carb and some other goodies.crank dynos over 400HP. |
| Advertisement
