Hey guys just picked up an 06 LBZ cc,sb, and absolutely love it. I am looking to buy somesort of tuner but i am up in the air as to which one to get. I want one that will basically just plug in and go. The truck is stock now and I plan on getting an exhaust sooner then later. What one would you use that will work fine with and without an exhaust. looking for a couple miles to the gallon if possible.
Thanks
I would do a PPE, and do the exhaust and that is where you will see the best mileage is doing both. Most likely a 2-3 mpg gain overall.
Tyler
__________________ 07.5 Chevy Summit White Reg cab LMM, Quadzilla steath 2, 5" MBRP straight pipe, 5" turn-down DPF Deleted, Cobalt boost & pyrometer, line of fire and ice. 5% tint. Banks Ram air intake.
Meyer Performance & Fabrication, LLC Home of your diesel performance needs. www.meyerperformance.com (812)-344-4421 Tyler Fass Sale for November pm for details.
I am not sure for the 06-07, but the install is easier on that engine than the LMM. I know there are no egr plates made any more for the LLY/LBZ.
Go to kennedydiesel.com for an EGR blocker plate thats where I got mine...get the Fingerstick as well cos your gonna get the codes if you don't. The PPE or Quadzilla are among the best programmers on the market.
__________________ '06 2500 HD CC/SB BullyDog TripleDog AiRaid CAI MBRP 4" Turboback Goodyear Silent Armor LT 285/75R16 EGR blocked w/Fingerstick
Yes about everything you do to the truck will. You could do a inline device such as Banks or edge. And a cat-back exhaust but with the cat intact you wont see the results, in perofrmance and mileage as with turbo-back.
I agree on the PPE, but the standard would be plenty. It has the same tunes as the first ones on the Hot + 2, it just doesn't have the big tunes on it. For the block off, since none of our vendors have it for a 06 try LBZ EGR Blocker Plate or http://kennedydiesel.com/categoryres...bCategory2=116. Without a exhaust and running a tuner i would not go over level 2 for daily driving or level 1 for towing.
__________________ KYLE
